Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have a kitchenaid ksra25f refrigerator freezer and i am having a problem with the water from the dispencer, the water is good but the of it self has little clear particles in it ,i change the filter and even the change the water line from the main water supply and i am still having the same problem.
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
Anonymous
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
Anonymous
  • 28 Answers
SOURCE: New Kitchenaid refrigerator often makes sharp bang noise.
I have an old Amana bottom freezer that does that. It's because the defrost heaters are doing their job and the area around them as well as the coil is expanding rapidly. Try making certain that the cabinet is level and not on an unsteady footing. You might want to try turning the T stat in the freezer to a lower setting. Usually between 2 1/2 and 3 1/2 works best in all freezers. If none of this helps and the banging continues, get used to it or get another fridge. It seems to be a failing in bottom freezer models for some reason. It's harmless but annoying. I actually know someone who says she has the ghost of a frozen turkey stuck in her freezer that's trying to get out! LOL!
Posted on Jul 09, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: Kitchenaid Refrigerator/Freezer Freezer is
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
Posted on Aug 18, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: how do you take out and change the water filter on
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Posted on Sep 24, 2009
Testimonial: "thanks for the help. "
Holiday mode refrigerator
If it is on Holiday Mode, press the key just once more. Page 8.
KitchenAid KSSC42QMS01 Use Care Manual
Jul 24, 2013 | KitchenAid KSSP48QMS Side by Side...
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Freezer doesn't make ice but water still works on front dispencer
HI,
I looked up your unit and the only problem I can see would be the full tube to the ice maker could be clogged with Ice not allow water to enter the ice maker, or a bad water valve which is located behind the unit on the back right side (freezer bottom). I would look at the fill tube start as this was more common.
I hope this helps
Water valve part number is you need is 4389177
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 23, 2011 | KitchenAid KSRA25ILSS Side by Side...
Water dripping from freezer section, into front dispencing area
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Apr 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Water dispenser does not work
The lines are likely clogged and will need to be removed and cleaned. Otherwise, although the pump starts, the valve may be clogged or non-functional.
Feb 11, 2018 | KitchenAid KSSS36QK Side by Side...
KitchenAid Superba KSRA25F - makes ice fine - dispensing motor not working
Hello!
Please check the "Troubleshooting" part of the manual, especially the part "The water dispenser will not operate properly"
Hope it will help!
https://manualsbrain.com/en/manuals/1409170/?page=23
Aug 31, 2017 | KitchenAid (KSRD22FKST) Side by Side...
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
159 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
