SOURCE: water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
SOURCE: ice freezes in the freezer in side by side fridge
dec the temp of ur freeze...................or reset your cooling point on defrost
SOURCE: Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
SOURCE: Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
SOURCE: KTRS22MGWH00
Here are a couple of tips that I wrote that will help you figure this out...
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
heatman101
1.
The first thing you must know is that your refrigerator should be
set at 37-38 degrees. Anything at 40 or higher and you are risking
food born illness (food poisoning) or spoiling your food. Place your
magnetic thermometer in the refrigerator.
2.
Set your dial on your refrigerator to the second lowest setting. (If
your refrigerator is already equipped with a digital thermostat,
simply set it for 37 or 38 degrees and do not move on to the next
step)
3.
After 2 hours, check your thermometer reading. If your reading is 38
degrees, there is no need to go higher and you are ready to put your
groceries in. Be sure not to open and close your refrigerator during
these two hours or your temperature reading will be incorrect.
4.
If your reading is higher than 38 degrees, move your dial up to the
next coldest setting and repeat the steps every two hours until you
reach the correct temperature for your refrigerator.
5.
Once you have reached the correct refrigeration temperature for your
refrigerator, place the magnetic thermometer in the refrigerator
permanently and watch for changes.
Typically, your
refrigerator temperature will need to be adjusted with the seasons,
a higher setting in the summer and a lower setting in the winter.
