Tektronix Phaser 860DP Thermal Printer Logo
stephen baer Posted on Jun 12, 2008
Tektronics phaser 850 - media jam
Hi i have a phaser 850 printer. every time the machine warms up. it says media jam on the front panel. There is no error code. any info or help would be appreciated. Thank you
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
448
Points
Exactly what 2 of mine are doing. I have no clue on how to fix this so if you find a solution let me know via e-mail if you can. My e-mail is [email protected]
Thank You
Need to clean up spilled toner in a Tektronics (Xerox) Phaser 780 how do i do this?
Best thing to do is just brush most of it out with an unused paintbrush. You can simply vacuum the rest out with the hose attachment. Hope this helps :)
2helpful
2answers
Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
1helpful
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
2helpful
Phaser 4510 claims repeated paper jams
The fuser exit sensor had an updated version for that model (old model has a "bounce" problem). Xerox gives a 1 year warranty..I would get them out to fix it pronto !
It is also helpful to have the error code. Press the i button while the printer has the jam message on the front panel. Use the fault code to locate where the jam actually is. (This will help the technician greatly ! )
Xerox tektronics phaser 850- media jam
The preheat entry sensor assembly probably has broken sensor arms, and will need replaced.
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jam At A
printers have sensors that tell the main board where the paper is, if a sensor is stuck or broken it will say jam, the question is where "A" is, look in the manual and see if you can find it, it will be either an optical or moving plastic.
hope this helps
good luck
2helpful
2answers
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Top Tektronix Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
