Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1: Move the printhead carriage back and forth a few times.
Solution 2: Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3: Press the ink pads down in the purge unit.
All The Best: Pineworks
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam. Solution 1: Move the printhead carriage back and forth a few times.
Solution 2: Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. Solution 3: Press the ink pads down in the purge unit. All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Canon lists the solutions for the error 6A00 as... 1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. Removing paper jams 4. The MP830 may require repair 5. Unlock the scanner lock switch (MP830)
In my IP 3000 during a print suddenly on the 3rd page, a big "crunch" sound. Paper was jammed - error 5100 or smthg, and managed to remove the paper... but then error 6A00 came up. I found this post and was saved. Manually moved the print head left and right, turned the printer on/off. Still the same error. Then I noticed a piece of torn paper lodged inside. Removed that, got inky fingers, and finally got printer in working condition.
Try to clean any foreign object inside.May be it can help you.
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Hi
Error 6A00
Solution 3: Press the ink pads down in the purge unit. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Open the top cover to the scanner, the lock switch is on the left hand side of the glass. It is about 1 1/2 inches oblong and SLIDES back and forth. The switch is black with 3 lines across it. Are you able to see it now? And your answer is ????
