if your computer came with
a motherboard disc the sound drivers could be on it click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question mark? Right click to reinstall
drivers or you can download the drivers
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800 AMD Morgan 200Mhz FSB CPU - 1.3G AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G AMD Palomino 266Mhz FSB CPU - 1.2G AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+ I hope that helps! Good luck. GaugeMan
if your computer came with a disk the sound drivers could be on it control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustmentsthere or control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers hope this helps
Hello there here is a pdf downloadable flile that will help you. best regards michael
[PDF]A7V133-VM
3051k - Adobe PDF - View as html
Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System PowerLED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
1. goto Bios setup diable your onboard display
2. get a new display card and its driver, fix it in
your computer.
3. install the display card driver.
4. your problem will be solved.
thanks
ehsan ([email protected])
