Question about Kodak EasyShare M1073 IS Digital Camera
I have a kodak easy share M1073 and cannot figure out how to reset the date. I can turn the date stamp on and off but that's the only option I have.
    Filmmaker:
    Uploaded 5 video answers.
  • 31 Answers
It's important to set the date and time so that pictures and videos are organized by the date taken. The date and time procedure varies slightly between camera models, but generally:
  1. Turn on the camera.
  2. Press the Menu button.
    If you see a Setup tab, press the Right arrow button to highlight the Setup tab. If you don't see a Setup tab, press the Down arrow button to select Setup, then press the OK button.
  3. Press the Down arrow button to choose Date and Time (or similar), then press the OK button.
  4. Press the Right/Left arrow buttons to move between year, month, and date. Press (or press and hold) the Up/Down arrow buttons to scroll through the year, month, and date.
    Use the same procedure to set the time.
  5. When finished, press the OK button.
NOTE: If your KODAK Camera has a touchscreen, the same principles apply. Tap the Menu icon, Setup, then Date and Time (or similar).
Posted on Nov 03, 2010
6ya staff
SOURCE:
How do I get the date the picture was taken stamped on the picture
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sep 18, 2014 | Kodak Cameras
I have a Kodak Easy Share Z650. The problem is I took pictures without realizing it was stamping with a date, which is not correct. The date is off by a couple of years in some cases. Is there anyway to...
Once the date has been stamped on the photo, it's there just like the subject's face or the overflowing trashcan in the background or whatever. You can edit the photo somewhat using a photo editing program, using the same process as deleting any other object in your photo.
Aug 20, 2013 | Kodak EasyShare Z650 Digital Camera
My Kodak Easy Share C300 only shows date stamps on still mode pictures and not time stamp I now think it does not have the capability to show time on still modes?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the time on the image, in the margins, or on the back.
Aug 10, 2013 | Kodak EasyShare C300 Digital Camera
Does the kodak easy share 183 have the date option on the picture
Sorry, it does not put the date/time stamp on a picture. However, it does embed the date/time the picture was taken in the metadata (extra info in the image file beyond just the picture), so you can sort on your computer by date taken.
Mar 01, 2011 | Kodak Cameras
I have kodak Easy Share m530 Digital camera,but how date stamp and time automatical add on picture taking ? pls advice me
In any mode, press the MENU button. Use up/down to highlight Setup (three horizontal sliders) and press OK. Use up/down to highlight "Date Stamp" and press OK. Make your choice and press OK.
Jan 26, 2011 | Kodak EasyShare One Digital Camera
How i can remove the date stamp from my kodak photo?.I hav kodak easy share M340.
Press the MENU button. Use left/right to select Setup, then up/down to select "Date Stamp".
Nov 16, 2010 | Kodak EASYSHARE M340 Digital Camera
How do i change the date stamp on my camera? Kodak Easy Share m1093
  • Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial.
  • 2
    Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu.
  • 3
    Press the "Down" button to change the selection to "None." This removes the date stamp.
  • 4
    Press "OK" to save the setting. Press "Program" to return to capture mode.
  • Oct 01, 2010 | Kodak EASYSHARE M1063 Digital Camera
    Purchased a Kodak easyshare M320 can not figure out how to set
    You have two options for getting the date printed on your pictures. One is to set the appropriate option in whatever software you're using to print. The other is to have the camera put it there in the image itself. This means that if the date happens to cover something important, you won't be able to get it back.
    To set the camera to put the date stamp on every picture, press Menu, use left/right to highlight Setup, then use up/down to access "Date Stamp".
    May 20, 2010 | Kodak EASYSHARE M340 Digital Camera
    How do I turn off the automatic date stamp?
    What you have to do is click the menu button right of the review pics button. Then click the joystick right then down until its on date stamp option. Click it and then then click the off option. And voila the date stamp is off :-)
    Apr 24, 2010 | Kodak EasyShare M1033 Digital Camera
    Kodak EasyShare M1073 IS Digital Camera Logo
    164 people viewed this question
    Top Kodak Cameras Experts
    Ekse
    Vitally Alcher
    FIKRET UNALIR
    FIKRET UNALIR
    Level 1 Expert
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
