Sounds like the brake is the problem. First unclip and remove the rear wheels. If you don't have the user manual you can get a copy at www.bugaboo.com but it's just a spring clip holding the wheel in. Holding the stub axel spin each wheel with your hand to check they spin freely. If not wash in warm water then spray with silicon spray. Now check the movement of the brake system. Spray the lever cable and brake shoes with the silicon spray. Lubricant does not effect the brakes as it works using teeth not friction. But wear will damage your brake by rounding off the teeth. Fit wheels back on and adjust the brake cable with the small screw at the bottom of the cable so shoes clear the wheel teeth in the brake off position.
