Panasonic Lumix DMC-TZ1 Digital Camera Logo
Posted on Jun 13, 2008
Video i am only able to shoot 9secs of video. The message say recording has stopped because of limited ammount of memory card. which size should i be using thanks Jo
A
Anonymous
Hi, the best thing you can do is to buy a 1 or 2 Gigabyte SD Card. Taking videos is at about ~100 MByte / minute. So if you take a 1 GIG-SD Card you may take ~10-12 minutes video or at a 2 GigByte SD Card you may take ~20-22 minutes (pure video).( But you may change to still picture in the meantime as you like).
Putting in the SD Card, swith on your camera, choose the video mode and push 'LCD Mode': there you'll see the info "R 22m47sec" on your LCD on the upper right position - for example.
This is the review-function and is your best way to check your video (while choosing the review-position on your wheel and than push the "6 o'clock"=review button on the camera and your video will start.
Have fun, you're also able to use the zoom-in while taking videos.
The DMC TZ1 is a beautiful camera.
Rolf
1helpful
How can i increase video recording time of my Nokia 6303 i Classic. I have 2 GB memory card but it donot record videos longer than 1 minute?
this is the most irrelevant and misplaced option (for controlling the size of a video captures by the video camera) (honestly even though i had the same problem , and somehow i find the option,and solve it ,but i`m nearly 1 hour wondering for the same option for you to solve your problem)
i had the same situation ,but mine was worse , my camera captured only 5 sec (you don`t have any problem for approximately unlimited amount of time for your capturing, even if you`re just using your 2GB memory card ,still is more than you can imagine : but remember your nokia 6303i classic ,could use additional storage device,and act as a host for that kind of device : you can easily connect your flash memory (by choosing the right usb adapter )directly to your nokia device,and your mobile detect this memory as a host , and all you need to do , is to change your saving contents location (actually , i connect my (8G Flash + 16G integrated ram reader) mp3 player directly to the phone by USB ,and through the os of nokia , i can browse , play ,locate,and set as saving place)
HERE IS YOUR SOLUTION: the reason that your camera ,capturing time is limited in time , is for limit of the MMS (multimedia messages) ...
  • go to your video camera
  • in the option menu you will find setting/video clip length (set it to MAX AVAILABLE instead of for MMS messages)(its better to set your photo/video storage to memory card or other folder in case you have much more available memory and need to capture 2 days of recording)...
  • IMPORTANT NOTE : it may you wont see the option the first time you select camera ,,make sure you select video camera/setting ,and the option will be there
(additional setting related) so to correct this ,you must go to your messaging setting (who the **** think that the reason may be in there ) select MORE / Msg. settings / multimedia messages
and set the MMS creation mode free (or guided maybe works)instead of restricted
and the default timing ,is define limit in time,if the option restricted ,is selected
HELP ME : i`m killing myself to find a software solution ,for monitoring my video recording ,on my pc monitor ,(in case i want to record my self :while playin music ),and something that make n.6303i act like a web cam ,,,then i can use an application for video recording ,and synch my capture button with ,record audio from another port (for high quality studio sound )instead of her poor microphone ,,, as a matter of fact i did find a solution (named : mobiola screen capture for xxx(mobile models)
and it says ,that its supporting n.6303i ,,nevertheless the app for the device is in *.sys format ,and i never see (and nokia ovi suit say`s so :your mobile doesn`t support this type of ,,,,) is there anyone out there overcome with this problem before , the n.6303i get airial directly to the wall ?
3helpful
How do i get video to workon my vivitar vivicam x327
Video Mode
Press the MODE button to select the Video mode.
Note: The camera has limited internal memory allowing you to record up to 20 seconds in QVGA. An SD
card (up to 8GB) needs to be inserted in order to use the video mode normally.
When the icon appears on the top left corner of the LCD screen this indicates that you are in Video
mode.
1. Prepare the object or subject you wish to record.
2. Press the Shutter button to begin shooting the video.
3. The elapse time will appear on the top right of the LCD screen and the icon will flash on the
LCD screen.
4. Press the Shutter button again to stop the recording and save this file in AVI format.
Note:
1. You can preview the AVI files in Playback mode or once downloaded to your computer by using
Quick Time and Windows Media Player.
2. When the camera's memory is full, the “Memory Full Insert a SD Memory Card to Transfer and
Shoot More video!” message will appear on the LCD screen when you attempt shoot more videos.
Download the test file from the internal memory to the PC or delete them to shoot more videos.
27
Alternatively, you can insert a SD memory card to expand the memory to record longer videos.
3. The LED will light up when the light condition is not good.
Video shoot problem
Download P2k advance editor from www.modmymoto.com. Extract it on your Computer. Then connect your phone via usb. run the P2kAE and select connect then go to services or something but its on the second. then go to video camera and select read from phone then increase the recording memory from 50Kb to 50Mb or higher if required you can also save videos in mp4 format. Note: don't go beyond the size of the memory card.
Memory card question
I think its just a warning message but it shouldn't stop you from recording to tape.
If you can pick one up and install it in the camera, that will get rid of it.
It should take SD cards. They can be anywhere from 64mb to 2 gig in size. You should use the high speed cards as well such as a San Disk Ulra II. Standard cards may cause quality issues.
1helpful
Initialising 5Gb micro disk for Fujifilm M603
There is a limitation with this camera and the size of memory cards it can handle. Larger cards than 1GB, are not recognized properly. You can however use larger cards if you format the card in the camera using the USB cable connected to your PC. Just connect the camera to your PC. In windows explorer select the camera drive, right-click and select "format". I have used this to get a 2GB card working with my 603. Beware that files larger than 1GB can not be stored on the card. I once had been recording a video at concert for about 30 minutes with the 2GB card installed (the camera got really hot during this shooting!). When hitting the record button again to save this giant clip, I got an error message "write error" I was a sad puppy that night.
1helpful
2answers
Video length
I had the same problem and considered buying a 512MB Xd card. However I simply reformatted my 1MB M type Xd card and I am back in business. I can record 15 minutes of 640x480 on it. Hope this solves your problem it is the cheapest fix around.
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
"Recording stopped. Record in internal memory "
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures
"Recording stopped. Record in internal memory"
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
