SOURCE: Shadow On Printout
Here are the possibilities: -drum blade is not cleaning well, take out toner look at the shiny cylinder ( drum) is there toner on it? change cartridge. - transfer roller ( black roller on bottom of machine that comes in contact with drum) take lint free cloth and wipe may need to be changed,
SOURCE: missing manual
Here are links to the manuals. You will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open them:
Users Manual
Quick Setup Guide
Software Users Manual
It seems to me that you are missing part of the print alignment procedure. See page 12-18 in Chapter 12, Troubleshooting and routine maintenance, of the Users Manual.
If the unit fails after two or three proper and complete attempts, the unit might need service. Contact Brother Customer Service for further troubleshooting -- see page i of the Users Manual.
SOURCE: Brother MFC 240C alignment problems
You can fix it with the alignment menu on the printer, it just takes a while if you know what to look for. Cut the '0' sample out of a alignment sheet. Compare this with your options & if the samples don't perfectly line up then pick the one that aligns closer to the ends of the '0' sample and repeat till it perfectly matches.
I have figured it out! I have a Brother MFC 240CN and I was having the same alignment problem and I followed the instructions from the printer prompt as well as the manual and it does not work.
So, this is what I did. I ran the alignment test print, then when it asked if it matches, I would say "No". And then I would pick number "8" to be the one that most closely matched "0" regardless if it did or not. I did this for the 600 and 1200dpi. Then when I ran the alignment test print again, it looked better! So I repeated it again and again picking "8" each time and it looked better with every test print. After about 4 or 5 tries, it looked normal again!
I hope everyone else with this problem will see this response and I hope it works too. I was getting so frustrated with this problem. Now I don't have to get it serviced or buy a new printer!
