Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
