SOURCE: P5V VM-DH + EAX1600XT SILENT (256) = problem.. nahh
Did you turn your current graphics card down to 256 colors(more then likely your old video card is built into the motherboard). You have to do that before you install the card or that may be causing your error.
Keep me posted,
Lee
SOURCE: i have a asus 7200 gs 256mb graphic card my pc keep restarting
Your PC keeps restarting because while playing your video card is highly solicited,and this causes overheating. The solution to your issue is to buy a cooling fan and attach it to the cooling grid.
If this solution worked for you please rate it. If you require further assistance feel free to post a followup comment.
SOURCE: ASUS P5SD2-VM GRAHICS PROBLEM
Firstly, check that you have latest graphics driver or not.
If not then download the latest driver of your graphics driver.
After that remove your old graphics driver and install the latest graphics driver and then install the latest DirectX 9.0c also for Win XP.
Note : After each and every installtion just restart you machine.
SOURCE: I can't install a GeForce 6200 graphics card
Also, if that card has dual outputs, such as 2 DVI connectors, try connecting your monitor to the other one.
SOURCE: I recently bought a Sapphire Radeon HD 4770 card
Hi there. Really you know, you have answered ur own Q!.
No it is not compatible. Best thing you can do is, get in contact with your supplier, make sure you can return goods with complete packaging, explain you ordered the wrong item and you would like to exchange for the correct specs card.
You should have to much difficulty, CCL I understand are only to please assit?
