Question about LG Washing Machines
Washing machine programme error
Macine starts the programme then after about 3 minutes programme stops and a message appears 'OE'. I have just moved house and cannot find the manual to understand what this means.
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Posted on Jun 19, 2008
How do we set the time to stop on a UPM ETW350? I know how to set the time to start but i do not know how to set the time to stop. Thank you
In wall timers and manuals are shown on following link.
http://waterheatertimer.org/Programmable.html#ETW
ETW350 manual:
http://waterheatertimer.org/UPM-etw350.pdf
Select from 3 different functions:
1) 24-hour Programmable
2) Countdown timer function so lights turn off after period of time
3) Random function so lights turn on randomly and house looks lived-in
I am not going to write out the steps because they show in the manual.
But a specific part of the manual might be confusing.
So add a comment and I will help until we will get the timer working.
Nov 20, 2010 | UPM Programmable Wall Switch Timer
Washing programme keeps stalling
Ok, this is a basic control fault within the logic chip set. you will need to replace this faulty control board/timer in this case.the replacement of the control/timer will fix this issue.
Jun 01, 2009 | Electrolux Washing Machines
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Outlook Express malfunctioning
  • Install FreePOPs and make sure it is running.
  • Select Tools | Account Settings... from the menu in Mozilla Thunderbird.
  • Click Add Account....
  • Make sure Email account is selected.
  • Click Continue.
  • Enter your name under Your Name:.
  • Type your Windows Live Hotmail address under Email Address:.
  • Click Continue.
  • Make sure POP is selected under Select the type of incoming server you are using..
  • Enter "localhost" (not including the quotation marks) under Incoming Server:.
  • Decide whether you want your Windows Live Hotmail account to use a separate Inbox, Drafts and other folders or appear under Local Folders.
  • Click Continue.
  • Enter your complete Windows Live Hotmail address under Incoming User Name:.
  • Click Continue.
  • Now click Done.
  • Go to the Server Settings category of the account named after your Windows Live Hotmail address.
  • Enter "2000" (not including the quotation marks) under Port:.
  • If Mozilla Thunderbird has not selected your default outgoing mail server for the Windows Live Hotmail account, or if you want to change it:
    • Go to the root of the Windows Live Hotmail account.
    • Select the desired account under Outgoing Server (SMTP):.
    • To add a new outgoing mail server — you cannot send mail through FreePOPs, but you could use another free email account's, say Gmail's or AIM Mail's — go to the Outgoing Server (SMTP) category and click Add....
  • Click OK.
By changing the user name, you can download mail from any Windows Live Hotmail folder (not just the Inbox).
Sep 21, 2008 | Microsoft Windows XP Home Edition
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Programming Belling xou181ss oven
Try Googling (belling)(xou181ss)(manual) without parens.
May 01, 2017 | Ovens
Error Code "OE"
sounds like your machine needs rebalancing..check the feet and floor to ensure it's level and balanced
Apr 25, 2008 | Washing Machines
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Washing Machines Logo
358 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
