You have likely lost one, probably the +15 volt power supply... This is possibly a shorted component or a short on the circuit board causing this. It takes some skills at troubleshooting to find this. Sometimes using a thermal imaging camera will show hot spot... other times you have to search with a millivoltmeter. The rude solo light is driven by an op amp that uses both polarities of 15 volts and to turn it on it pulls negative... Hence I suspect the +15 is missing.
