Http://www.mrheater.com/ProductFamily.aspx?catid=41 If Spark electrode produces spark but pilot does not light.
Which model do you have?
TROUBLESHOOTINGINFORMATION:
If Spark electrode does not produce spark.
CHECK
• Spark electrode broken - replace ODS (Oxygen Depletion Sensor).
• Igniter wire may not be attached to spark electrode.
• Igniter wire damaged - replace.
• Piezo igniter defective - replace control valve.
CHECK
• No gas to heater - install disposable cylinder or connect hose and filter where required and turn on valve at remote cylinder.
• "PILOT" position not properly aligned - turn gas control knob to "PILOT" position and depress.
• Pilot is blocked from spider web or dirt - clean pilot, see MAINTENANCE.
If Pilot flame does not stay lit when knob is released.
CHECK
• Control knob in "PILOT" position not completely depressed or held in long enough to purge air from lines.
• Pilot flame not surrounding thermocouple - clean pilot, see MAINTENANCE.
• Pilot Assembly defective - replace.
• Tip switch wires disconnected - connect.
If Main burner does not ignite.
CHECK
• Main burner orifice is blocked - clean burner, see MAINTENANCE.
If Heater keeps shutting "OFF" during normal operation.
CHECK
• Pilot is blocked - clean pilot, see MAINTENANCE.
• Provide minimum fresh air opening of 9 square inches (example 3" x 3" opening).
• Tip over switch activated from bumping heater. Re-light.
• Regulator defective - Replace regulator.
• Internal contamination - Replace control valve and regulator.
• Call Technical Services for additional information.
One can ask Mr. Heater a question at the following website:
http://www.mrheater.com/ContactUs.aspx
I would contact mrheater.com athttp://www.mrheater.com/ContactUs.aspx
because this is their product.
undoubtedly one of these solutions will work if I can figure out how to get the unit apart to do the troubleshooting and servicing. Is there a diagram or secret to doing this?
