You will need a ball joint press for starters
REMOVAL & INSTALLATION
The lower ball joint is integral to the lower control assembly and cannot be serviced individually. Any movement of the lower ball joint detected as a result of inspection requires replacement of the lower control arm assembly.
SOURCE: replace lower ball joints
if you have some mechanical knowledge, it is not really difficult. It is just time consuming. Pick up a Haynes manual and they will give you a step by step with pics in doing this.
SOURCE: REPLACING LOWER BALL JOINTS ON 2000 FORD F250 4X4 7.3L DIESEL
hello,yes you do have to take the hub off to replace the ball joint with the ball joint being on the back side of the hub. hope this helps and please rate this.
SOURCE: 2000 Ford Taurus. How do I change a ball joint?
Lower Ball Joint
Inspection
Removal & Installation
To Remove:
