SOURCE: general error Delete all print jobs and turn the
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
SOURCE: My printer tx110 series has a general error it
If your printer jams frequently, you may be loading too much paper. This
can also occur if you’ve had jams in the past and have a piece of
debris still stuck in the printer.
Use a flashlight to examine the
entire mechanism to ensure no paper is still inside. This can also
happen if an internal gear is damaged. You will often notice one side
being fed faster than the other.
This could me the printer is physically
damaged and needs to be replaced or repaired. You may need a professional help and send it out for repair.
Let me know for any clarifications.
SOURCE: Delete all print jobs and turn the printer off.
1. Uninstall all the printer drivers (Software inclued)
2. Power cycle the PC
3. Re-install the drivers and software
4. Finally plug in the printer
SOURCE: my printer Epson t13 has
do you have a ciss t13 printer?.. coz if you have , then the problem is in your hose installation is short, if its not then your michanichal gear is broke,.. you have to bring it to its service center
