Televison & Video Logo
Posted on Nov 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't pair my remote to the tv. - Televison & Video
Joaquim Martins
Level 3:
Genius:
  • Master 1,128 Answers
  • Posted on Nov 06, 2010
Joaquim Martins
Master
Level 3:
Genius:
Answers
1128
Questions
0
Helped
298241
Points
3333
Check your tv brand and model, writen on the middle/botom case label. and check at your local electronics store , for a new one.
My Samsung solar remote blinks but will not sync at all the Bluetooth icon appears on the TV tho
The issue with your Samsung Solar Remote not syncing with the TV even though the Bluetooth icon is appearing on the TV could be caused by a few different things. Here are some troubleshooting steps you can try to resolve the issue:
  1. Check the battery: Make sure that the battery of the remote is charged and inserted correctly.
  2. Move the remote closer to the TV: The remote should be within 30 feet of the TV to ensure a strong Bluetooth connection.
  3. Turn the TV off and on again: This can help to reset the Bluetooth connection between the remote and the TV.
  4. Remove the pairing information: If you have paired the remote with another device before, it may have saved the pairing information and is interfering with the new pairing. Try removing the pairing information from the remote and the TV and then pair them again.
  5. Reset the remote: You can reset the remote by removing the battery, then pressing and holding the power button for 10 seconds, and then releasing it. Reinsert the battery and try to sync the remote again.
If these steps don't resolve the issue, try contacting Samsung support for further assistance.
How do I pair an Amazon Fire television remote to a different television please?
Question edited for clarity. Thought it was a remote for an electric fire. Capital letters matter :>)
Go to Settings on your Fire TV.
Select Controllers & Bluetooth Devices. Select Amazon Fire TV Remotes. Press and hold the Home button for 10 seconds to pair your remote.
Pair Additional Fire TV Remotes - Amazon Customer Service
More here and videos
https://www.google.com/search?q=amazon+fire+tv+remote+setup
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
My Samsung remote is BN59-01134B. I cannot remember how to program it to my TV I don't remember the code to program it to my TV I'm totally lost please help
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Instructions to control samsung t v
  1. TV off
  4. Turn on TV
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  4. Turn on TV
  1. TV off
Within 3 feet of TV
Please rate if Helpful.
Good Luck !!
My samsung 3D led multisystem smart TV remote control does not work anymore
  1. TV off
  4. Turn on TV
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Remote will not work
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Samsung tv has never responded to the remote control
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
2answers
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Try this:
  1. TV off
  4. Turn on TV
Good Luck !!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
