Question about Hoover Nextra HNF 3157 Front Load Washer
I have a hoover nextra hnf 3157/80 and need instructions to change the door hinge.
6ya staff
SOURCE:
Anonymous
SOURCE: Water leak at rear of
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Posted on Jul 30, 2008
Mukesh Kumar
  • 3230 Answers
SOURCE: Hoover Washing Machine Door wont
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
Anonymous
SOURCE: Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
Posted on Jun 02, 2009
Anonymous
  • 61 Answers
SOURCE: HELLO , I HAVE A HOOVER NEXTRA MEGA LOAD WASHING
Hi John,
it has been a while since i worked on one of these, but I might be able to talk you through it, first make sure you have the correct bits to replace. i.e. the inside of the handle and the latch match the same that is on that you can see before you go any further.
using a torx size 15 I think remove the two screws on the door hindge, and then remove door by pushing up by a 1/4" then the hindge should pull away from the machine. using a torx size 10 then proceed to remove the four screws from the inside of the door frame, ease the door pannels appart and the glass bowl and lock should be exposed. there should be a further two screws holding the latch in place, just be careful when taken these out as they may be under load from a spring, note the positions of the latch and replace all back in reverse order.
Cheers,
Posted on Sep 07, 2009
Danny
  • 160 Answers
SOURCE: How do you repace the door hing on a AAA140 Hoover
should not need to as the 2 screws holding the hinge to the frontplate of the machine goes into a threaded nut welded to the panel (a torx 30 or 40 bit is needed).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
Posted on Dec 18, 2009
Testimonial: "Thankyou very much. Didn't know it came off so easy. It worked like a dream"
Machine wont sart
Your door lock/latch is broken, this is a common issue with front loading washing machines and the only way to fix it is to replace the door switch.
Mar 05, 2012 | Hoover Nextra HNF 2137 Front Load Washer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
I need to fix the handle of a hoover washing machine hnf3157.I have the kit but can work out what way round the spring goes. Please help. Thank you Silvia
the hook faces away from the center of the door.
The handle goes around that.
The spring goes around both, on the inside of the hook, facing the center of the door.
Jan 16, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Water leak at rear of drum on Hoover Nextra HNF 3157 washing machine
Jul 26, 2008 | Hoover Washing Machines
Hoover Nextra HNF 3157 Front Load Washer Logo
57 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
