Generally when a zoom extends to max, it defaults to a higher aperture number - which means a smaller hole that lets in less light. The auto settings then increase the ISO (light sensitivity) to compensate. If you hit the high end of the ISO for your camera, you get grainy photos.
Try the same 'full zoom' on a bright day - and you should see the difference. The ultimate cure? Stick to brighter situations or spend money on a body with a higher ISO sensitivity or a lens with a fixed aperture. The least expensive approach is to shoot in situations with more light.
SOURCE: 18-55mm lens won't zoom
DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
SOURCE: Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
Hope this helps!
SOURCE: Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
SOURCE: My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
