The problem is the print head, The ink cartrige for this printer is just a little bottle of ink. What really causes problem in it IS THE CLOGGED HEAD. If you have skill to reach thepen of the head (part that touchs the paper) use a quill tip or rag soak on water and clean it. Or go to EPSON SITE AND ORDER A HEAD CLEANNER FLUID TO POUR INSIDE THE HEAD AND CLEAN IT.
I think there are 2 causes epson c 63 printer not print problem.
First one is: Your ink cartrige are not install properly.
Solution: Try to install ink cartrige properly, in this time please clean ink cartrige chip as well as connector.
Secoundly: printer main board problem. Print data does not pass through main board.
Solution: Please replace new one.
I think you will relive from the problem.
Thank yoou.
At a guess you've bought a compatible generic cartrige. I had a similar problem different printer.
I had to by a genuine cartrige, worked fine. Contacted the generic cartrige provider, explained the problem. Returned cartriges and got refund no problem.
It looks like the generic cartrige makers are seeing some solutions to chipped cartridges but not all.
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
It sounds to me like you don't replace the cartridges, but have the ink refilled in the cartridges? This can only be done so many times until the cartridge jets become plugged and therefore can no longer print. You can try appling alcohol to a q-tip and cleaning the cartridge's jets where the ink comes out, but most likely, you will need to purchase new cartridges and start over.
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
