SOURCE: Mirus Desktop Computer
green-white for front panel Power indicator LED , Blue-white for RESET Switch , Orange-white for POWER BUTTON , Red-white for HDD LED . The berg pin header on the motherboard will have these legend printed just beside the connector or due to lack of space slightly away from it .
SOURCE: dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
SOURCE: I HAVE TAKEN OFF ALL THREE POWER CORDS FROM THE
Green White is for the power switch. Red-White is for the HDD LED and Black-white is for manual reset. Look at the plastic clips at the end of these wires. Generally they it written on them.......sodeep
SOURCE: thers 4 wires to connect 1 red 1 black 1 white and
Well, if there are no color lights on this strobe effect, a fairly standard color code for AC is Black is HOT White is Neutral, no insulation is ground and Red would power your strobe ( I Think )., I would hate to misinform you. Is this an AC powered strobe? Like when you wire up a ceiling fan you have the same color code. I'm sorry I can't help you further, and messing with live AC can be unsettling.
SOURCE: i need to find out where the 3 little plugs go
Sometime these connectors from the desktop case front panel have labels indentifing what each connector/plug is for. From your description they could be a reset switch or LED indicators for hard disk or power light etc.
If the plugs are not labeled then trace the wires back to the front panel to identify what they are attached to.
When you connect the LED indicators to the motherboard and it does not light up when they suppose to, then turn the plug around 180 degrees.
The LED are polarity sensitive ie they only light up if the + and - leads are connected to the motherboard correctly.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
This box also appears during normal system operation if the video cable becomes disconnected or damaged.- Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
