Remove MMC from ur mobile,then switch on ur mobile then press restore key that is *#7370# after inserting this u have to enter 12345 as factory code, then it will start
You cant d the firmware upgarede yourself for s40 phont, ie 6230i, So you have to take it shop, they use to flash the new firmware with special software at minimal cose...
Try resetting the phone to factory setting if it doesnt work try taking it for flashing
remove the memory card and try it work's properly. after u just insert
the memory card i likely to be working.. better u need to format the
memory card..
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
this is your 10 digit master code.. keep is safe because this cant be changed, only security code can be changed. this code will work everywhr whr it asks for SECURITY CODE (ex keypad unlock with security code, reset phone to factory settings, etc.)
same----------
