C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
SOURCE: Electrolux dishwasher wt65h shoing
If there is a set button hold it in for 5 secs!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Hello cjsmith12345 - Are you certain the error code is C8? However, if you are receiving an error code E08 it typically indicates a shorted keypad, or a faulty User Interface Board. Depending on the model, these components may be the same. To reset, turn the power off to the unit for two minutes. This may be done by either unplugging it or flipping the household circuit breaker off and then restart unit. If error reoccurs, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
