How to change to rear tire
To remove a 2008 Touring rear wheel FIRST raise the bike with the rear wheel off the ground, remove the saddlebags, inspect the wheel bearings, remove the left side muffler, on (FLHX) models equipped with low profile shock absorbers the remove left side lower saddlebag support rail, if ABS equipped cut the cable strap to release the rear wheel speed sensor cable from the brake hose to the brake caliper, remove the two socket head screws to release the brake caliper from its bracket, remove the brake caliper from the brake disc, pry the inner and outer brake pads back for additional clearance as necessary using a stiff putty knife with a wide thin blade to avoid scoring or scratching the brake disc, set the brake caliper on the passenger footboard, remove the E-clip from the groove at the end of the axle, loosen the cone with an AXLEfNUT TORQUE ADAPTER available from JIMs or H-D to get up between the axle nut and the right side muffler, remove the cone nut and adjuster cam from the axle, rotate the weld nut on the opposite side of the axle in a counterclockwise direction until the wheel is loose, use a soft metal drift to tap the axle towards the left side of motorcycle and catch the external spacer(s) (noting their place and orientation for reinstallation), pull the axle free of the rear swingarm, the caliper bracket, the rear wheel speed sensorf(if ABS equipped), and the wheel hub, keeping the ABS wheel speed sensor and ABS encoder bearing away from al magnetic fields such as magnetic parts trays, magnetic base dial indicators, alternator rotors, etc etc to avoid destroying them, remove the caliper bracket from the anchor weldment on the rear swingarm, move the wheel forward and slip the belt off from the compensator drive sprocket, hold onto the compensator drive sprocket while removing the rear wheel so that the isolators will not fall out, if necessary, remove to remove the brake disc remove the five fasteners and release the disc from the hub after marking the disc and the hub for re-assembly alignment in their original position.
To install a 2008 touring rear wheel FIRST reinstall the brake disc in its original orientation if it was removed and tighten the fasteners alternatively to 30-45 ft-lbs (41-61 Nm), ensure that the compensator sprocket is square and fully seated in its proper position, put the wheel into the rear swingarm and slide it forward and put the belt over compensator sprocket and then move the wheel back to take up the slack in the belt, install the caliper bracket on the anchor weldment of the rear swingarm, apply a light coat of wheel bearing grease onto the axle, the bearing bores and the bore of the spacer sleeve, insert the axle through the left side of the rear swingarm, the thin external spacer, and the rear wheel drive compensator sprocket into the and through the wheel hub left side and out the right side, through the rear wheel speed sensor (if ABS equipped) (the grooves on the external spacer, or index pin on the wheel speed sensor (if ABS equipped), are on the outboard side) or the thick external spacer if not ABS equipped, the caliper bracket, and the right side of the swingarm, rotate the axle so that the flat on the threaded end is topside and then with the thumb down and the cam forward install the adjuster cam on the end of the axle, avoiding contact with threads apply a thin film of LOCTITE ANTI-SEIZE lubricant to the inboard side of the cone nut, install the cone nut on the axle finger tight, obtain torque wrench with 1/2 inch drive head and the AXLE NUT TORQUE ADAPTER, install the torque adapter perpendicular to torque wrench ONLY or applied torque will be inaccurate, insert the tool up between rear wheel and the muffler and onto the cone nut, verify that the adjustment cam just contacts the weld nub on both sides of the swingarm (if necessary, push the wheel forward somewhat to do this), if ABS equipped route the sensor cable forward and outboard of the caliper bracket and then continue forward with it following the top of the swingarm, rotate the wheel speed sensor in a counter-clockwise direction until its index pin makes contact with the caliper bracket at its proper contact point, tighten the cone nut to 15-20 ft-lbs (20-27 Nm), properly position and install the brake caliper, align the holes in the caliper with the holes in the caliper bracket install the two socket head screws and alternately tighten them to 43-48 ft-lbs (58.3-65.1 Nm), install a new cable strap 1.25 in. (31.8 mm) in front of the brake hose crimp capturing the rear wheel speed sensor cable and brake hose together, using a belt tension gauge adjust the drive deflection to FLHR/C 3/8-7/16 inches or 9.5-11.1mm; FLHT/C/U FLTR FLHX 1/4-5/16 inches or 6.4-7.9 mm at the loosest spot in the belt, holding the weld nut on the left side of the axle tighten the cone nut to 95-105 ft-lbs (128.8-142.4 Nm), loosen it nut one full turn, retighten it to 95-105 ft-lbs (128.8-142.4 Nm), recheck the belt deflection, install a newE-clip in groove on right side of axle with the flat side out, on (FLHX), models with low profile shock absorbers properly install and torque into place the left side lower saddlebag support rail, install left side muffler, verify that the exhaust pipes are in alignment and do not contact the vehicle frame or mounted components, tighten the TORCA clamp to 45-60 ft-lbs (61-81 Nm), pump the brakes to position the pad against the brake disc, install the saddlebags and road test the motorcycle for proper operation.
