Fuji FinePix A400 Digital Camera Logo
Posted on Nov 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on the camera fuji f480 digital camers it shows me zoom error on screen
CameraR
Level 3:
  • Fuji Master 4,738 Answers
  • Posted on Nov 09, 2010
CameraR
Fuji Master
Level 3:
Answers
4738
Questions
Helped
1195823
Points
12483
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
FinePix F480. Zoom keeps coming out at an angle and jamming so that it won't return into casing.This gives 'Zoom Errors.'
The lens needs to be replaced, or if you can try and SNAP the lens back towards center so it's not at an angle you might be able to fix it. Most likely not though, and you will have to replace the lens.
Thomas
ZOOM ERROR
Camera malfunction or fault.
Turn the camera on again,taiking care no to touch the lens
Turn the camera off an on again ,if the message still apears ,contact your fujifilm dealer.
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Zoom error the zoom will not comeout when the camer is urned on, is this somethinbg i can fix
No - it is broken..,
Unless you have a good camera shop near you, it will probably cost more to fix than replace.
1helpful
My finepix f480 says !ZOOM ERROR on power up and switches off. Any suggestions as to whats wrong?
Does the lens retract and extend fully? Because of the design of the lens It is possible that the internal lens has jammed or is damaged. click on my profile and email me and I may be able to help
2helpful
2answers
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
2helpful
FUJI FINEPIX F480 GET HANG AND CARD DOES NOT STORE IMAGES
i formatted it in cam only now it's workin good.....dont format in computer it will show this kind of errors
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
