All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties. NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page NOTE:To access the router's web-based setup page using Mac, click here. Step 1: Step 2:
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead. The router's IP address can be changed by: 1. Running the router's setup CD. If you forgot the router's IP address you can: If you forgot the router's password you need to reset the router. For instructions, click here. Windows XP The router's password can be changed by: i. Running the router's setup CD. Click here to learn how to download firmware.
Open a web browser such as Internet Explorer.
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192i need to get into my nat settings - 3676-003.pngbr />
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
