Samsung Digimax S730 Digital Camera Logo
Posted on Jun 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black spot on the lens
I have a black spot and it sudenlly apper on the lens and i can see it on the lcd so is it a problem in the lens or what???
  • khaled13 Jun 16, 2008
    ya it appear in the photos and i have tried to clean it but still...
Tim Babcock
Level 3:
  • Samsung Master 2,794 Answers
  • Posted on Jun 16, 2008
Tim Babcock
Samsung Master
Level 3:
Answers
2794
Questions
13
Helped
1127714
Points
7249
There could be dust on lens. You could try cleaning it.
Does it appear in your pictures?
  • Tim Babcock
    Tim Babcock Jun 16, 2008
    It could be in the CCD unit. It should be taken into the shop for someone to look it.
To remove a black spot on a old sharp model TV?
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years,
and the price is USD190
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
HOW TO SOLVE BLINKING BLACK SPOTS IN MY NIKON D70
I can duplicate your issue on my Nikon D810. You may have set it to display the areas that are over exposed or "clipped". Go to "Playback Menu", select "Playback display options", uncheck "Highlights".
I have a huge black spot on the LCD lens, I would
The display being spotted can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is seen to be spotted, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Thank You for using fixya
2answers
Blue diust specs constellation like!
If you are seeing the "spots" when a black screen is projected, the problem is likely to be scattering caused by dust on the lens. If you can get at both ends of the lens assembly, clean both sides using lens tissue. If the spots are seen at all times, there may be damage to one or more of the LCD panels.
Please update this with your results of the cleaning.
Thanks,
Dan
Sony DSCW50 Black spots on image
Sony will replace lens assembly.
I'm not sure about qualified local camera tech will apart lens assembly to clean it.
1helpful
Black spots
possible moisture and or contaminants in lens assy .More likely the lens would have to be replaced. These lenses are not servicable try alamo camera service .com
1helpful
Black spot on pictures, and lcd viewing
Hey cj17,
Since this spot is both on your lcd and your pictures the lcd is most likely not to blame. This spot is probably caused either by dirt on the lens or the sensor, or it could be caused by a dead pixels on the sensor. You can try cleaning the lens, and if this doesn't work you should have it looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
Lens cap test...
Switch on camera into Shutter mode. Put lenscap over lens or block it so you get a black LCD. Have a look at that first. Only a general indication but if there ARE any bad pixels on the LCD they will be visible as coloured dots. Not too important as THAT doesn't affect the pic but personally I would not put up with it - took one back for exchange for that reason .. who wants to look at spots. The CCD is the real one to look for. With lens still blanked off to a black screen set the shutter at 2 secs, take a pic then set at 4 secs, take another pic. You won't see much on the LCD so you should download those tests to your editior - Paintshop Pro, Photoshop or whatever. THEN you get a much bigger pic (black) to look at. You'll probably find at least one or two little spots, almost inevitable with many, but you should NOT get many and also very noticeably bad spots. If so , complain and exchange.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
