Question about Brother HL-2070N Laser Printer
Printer will only print one page at a time when printing multiple page documents. It will pull the first page, print it fine, then indicate a paper jam. It has not picked up the second page from the tray and there is no jam in the printer. If you pull the paper tray out, put it back in and push the blue button it will print the second page. Then you have to do those steps all over again for each page thereafter. I have three printers doing this exact same thing. I have changed toner, drum, made sure paper selector in paper tray was correct size, and checked all settings on the computer (printer also does this when printing a self config page [blue button 3 times] so I don't think it is a software setting from the PC) please help!
    Sergeant:
  • 331 Answers
Some printers have setting that as the toner cartridge is low will allow you to only print one. Check your toner...
Posted on Mar 28, 2017
5 Suggested Answers
6ya staff
SOURCE:
Everett Lin
  • 990 Answers
SOURCE: my brother mfc-8460n printer allways prints from the manual tray
sounds like after setting you didn't lock in, don't forget after setting you have to hit enter or yes key
Posted on Dec 13, 2008
Just4help
Jeff
  • 145 Answers
SOURCE: Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
Posted on May 26, 2009
Anonymous
  • 239 Answers
SOURCE: Paper jams, remove toner put it back then restart printer!
May be the rubber rollers are coated with dust
Clean it and try after it dries.
(Plz do not use 70grammes papers)...use 80g
Posted on Feb 06, 2010
Anonymous
  • 59 Answers
SOURCE: Everything was going fine for 5 years. Today, I
The lights you describe indicate a "CPU Runtime Error",.. unfortunately this may mean a trip to the shop for the printer. You can try to clear any obstructions and turn off and then unplug the power for about 4 minutes,.. plug the power back in and turn on the printer. If this does not have any affect (most likely it will not,.. but its worth a try before servicing), then you have a mainboard problem and will require parts and labor to fix.
Sorry to be the bearer of bad news,.. but without the news you will spend a lot of time trying to correct a problem that requires a repair.
Posted on Feb 08, 2010
Will not print from the computer to the printer. I brought up a picture and pushed print and it just pulled in the paper and it was blank
* Check your warranty. Call for support.
*** Following is for information only.***
* Brand, Model for specific solutions.
* Computers and printers perform many functions.
* Just printing B/W documents are a thing of the past.
* Just printing a document requires the user to identify:
* Size of paper to be used. A4, 5x8", 8x10, banner, etc.
* Quality of paper; Plain, semi gloss, bright white, photo, etc.
* Orientation of document or picture; Portrait or Landscape
* Multiple copy.
* Size of document; Standard paper, Multiple (expanded) poster, Shrink (Reduced to fit page), Reduced to wallet size., etc.
* Color shift (effects) Print in grey scale.
* Print in reverse for T-shirt transfers or window posters.
* many more options depending on the printer. (some print on cakes)
* The point is that these or most of these have to be set up by the user EACH TIME you need to print something. The printer may be set for poster sized pictures but you just want to print a simple letter. This poster setting (depending on how many sheets per poster) may be the upper right corner of the document is blank. It did print but it started in an area that does not have anything to print.
* Another issue with printing (more common) is how many sheets are you printing. Depending on your CPU speed, each page needs to be processed (rendered) to be accepted by the printer. My Lenovo ideapad takes 2-3 mins to render 1 page. Printing 15 pages (or copy) takes over 30 mins to render before it prints the first sheet.
* Which order of print? Was the last page printed first? Is the last page blank?
* Wireless printers also take time to transfer data to the print buffer. This is also depends on your router or WiFi speed. (or network)
* To check your setup use the "Preview" option. Not how the document is pictured on the printed sheet. Pre-view saves on wasting paper on miss prints due to incorrect settings.
* Check your printer manual on setting up for a specific paper, document size, quality, and other issues.
Aloha, ukeboy57
PS, the issue of lost connection (WiFi) will stop the print. Eject the last page (partial print). Some machines will eject page only after a restart or reset.
* Perform a "Test Print" using the printer test mode (to check if the printer is out of ink.)
* Perform a print of a single page letter from the computer to test the connection to printer.
* Use the computer to check the printer app. look at the ink levels. Perform a system check of the printer operations.
Jul 27, 2018 | The Office Equipment & Supplies
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
Printing errors
Try printing one page at a time and see what happens. Repost!!
Jun 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Pulls in multiple sheets of paper
you must not use thin paper. you should use thick paper so that it will only pull one paper at a time...
Apr 18, 2009 | HP DeskJet 940c InkJet Printer
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Nov 21, 2008 | HP LaserJet 3380 All-In-One Printer
My HPOfficejet Pro K550 will not print checks correctly
Hi crys smith -
for future refs: if the paper type and size (in this case checks) is set up correctly in the software that you are using to create the checks, perhaps it would help to check the printer settings. this link at hp support might help you then:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00494598&dlc=en&product=501369
it includes checking and changing print settings and stopping a print job. (-and no one wants to waste checks!) -JW50
Aug 26, 2008 | HP OfficeJet Pro k550 Printer
HP LaserJet P2015dn
sounds like you're dealing with Postscript issues here. Does your HP have postscript drivers installed.
you might want to check on the current Mac drivers through this link
Mar 08, 2008 | HP LaserJet P2015dn Printer
Brother HL-2070N Laser Printer Logo
1,276 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
