SOURCE: Trouble removing the seal nut and the long screw that hold that bottom agitator
If your machine has the plastic nut, I use a pair of channel lock pliers to remove it. It usually will break but you will need to replace it any way. To get the basket support off, I use a piece of flat steel and large hammer. This will need to be replaced also. The new basket support has a seal in it that takes the place of the plastic nut.
I assume you are replacing the bearing and seal since the bearing wearing is usually what causes the seal to leak.
Post back if you have any questions.
Thanks/Mike
SOURCE: Maytag PAV2300
My opinion is no. You need those tools for reinstalling so you dont break the parts you are installing
SOURCE: mah3000aww leaking water
You need to replace both tub bearings and the seal. Not an easy job. Good luck, though.
