YouTube Videos Logo
Posted on Nov 11, 2010
How to download video from camcorder to disk - YouTube Videos
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
268
Points
6
You got to check first if your camcorder has a digital video out (firewire / ieee 1394) or an analog video out (rca connector)
If it has a digital, your life will be a little easy. If its analog, you will need two important computer component namely a "video capture card" and " a "Software" that will record your video.
Assuming, your camcorder has a FIREWIRE output. Here are the steps for your setup.
1. Connect your firewire cable from your camcorder to your computer. There are different connectors for the firewire but the usual wire that comes with your camcorder are 1394-4p to 1394-6p. You can check the types on this site; http://www.tca-inc.net/firewirecables.html
2. After connecting your camcorder to your computer, launch your software that will record you video, For MAC users typically its FinalCut Pro and for PC its ADOBE Premiere. But any software will work.
3. Power-on your camcorder and let your computer detect your camcorder. If your camcorder comes with a software installer, then you will need to put it in now.
4.Your video capture software will give you a preview of your video and will probably give you a setting you need to customize. frame size or resolution - 320x240 pixels (this is a low resolution setting) - 720x480 pixels (this is the standard for DV and popular TV formats)
Audio setting - 16bit 44.1khz
5. After setting your video resolution, you are ready to go. Watch out for DRIVE SPACE cause video eats up alot of space, and it all depends on your settings. The higher you go the bigger you file is.
If your camcorder doesn't come with a firewire output, then it will be a little technical for you.
1. You got to buy a good video capture card. There's a lot of brands out there ranging from consumer (cheap) to professional (expensive). Quality always comes with a price.
2. Install your video capture card into your computer and install the software that comes with it. Consumer brands are typically easy to install but if you encounter a few snag on your installation, go to the brand's technical site or forum so you'll get first hand info from actual users. Never give up. alot of times the sequencing of installing the drivers is the key to success.
3. after installing your video capture card, launch the software that comes with your capture card to grab your video. set your video resolution and you're ready to go.
JS
Lost my imagemixer 3 for panasonic sdr-h200 camcorder in a fire. Where can I download or get a cd.
I have lost my panasonic SDR-H18 imagemixer 3 CD software disk. Is it possible to buy a new disk, or download a copy
2answers
Flip Video Ultra Camcorder: I accidentally deleted footage from my Sony DCR-SR...
You can use a camcorder recovery software, recommended asoftech data recovery as it helped me before. use link below to download:
Camcorder deleted video recovery
You may refer to this file recovery tutorial which is very useful
2answers
I recorder my video on non- SONY DVDs. Now the video is showing only on the camcorder but on other medias like my laptop and DVD player it is showing as a blank. Is there anything I can do to correct it or...
It may just be the format that it was recorded in. Try downloading vlc player then try to play the video from the dvds. You can download it here:
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html
5helpful
3answers
I accidentally deleted all video from my Sony Camcorder DCR-SR60. Can I recover this?
You can use a video recovery software, recommended asoftech data recovery as it helped me before. use link below to download:
Camcorder video photo recovery software
7helpful
2answers
Can you Recover a deleted video off the camcorder?
yes, you can recover deleted videos off camcorder with camcorder recovery software, recommended asoftech data recovery as it helped me before. download the software with link below
Camcorder video recovery software
you may refer to this video tutorial
2answers
Camcorder PC Software
Ditto can I get or download pc software for the Dz-hs3ooA video camera/recorder from somewhere?
Lost disk to be able to download video onto computer
Download free application WINDV (Small Windows utility for DV FireWire digital video input/output ).
buy and connect a firewire cable between camcorder (DV output ) and a firewire input in your pc, if you not hasn't got one, buy it. you can buy a card with this kind of inputs.
Connect and run application, play camcorder, and record to your pc, your video.
Top YouTube Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
 Grubhead
Grubhead
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
