Dynamic link Library file called "graphic .dll". Before you visit the link below, you need to know exactly which programme is reporting this as missing and get the correct name of the missing file. You then will need to read the "how to install dll files" in the third link to do it properly. I cannot guide you through the process personally, without knowing more about the missing file. Normally you can just copy the downloaded file into the Windows /System, but as i mentioned, follow the guidelines in the third link
Graphic.dll appears to be part of windows, although I'd scan it if you download it to be sure
http://www.nodevice.com/dll/graphics_dll/item7308.htmlDon't click on download their registry booster or scan service, just download the file after entering the verification code
These links can help.( read the info on installing)
http://www.afreedll.com/search.phphttp://www.makeuseof.com/tag/how-to-fix-missing-dll-file-errors/http://dllcity.com/
