I have a Panasonic PT47WX53G it wont turn on or off (Red light continues blinking 2-3 second intervals) R517 Burned out and I found on the net that it was a 47k Ohm resistor, however I have also noticed that there are other talk fourums that said it was a 10k resistor. Could someone please help me identify the correct specifications? I was also hoping to find out if there may be other common issues associated with the over heating of R517. Thank you so much!
SOURCE: Vertical lines and big red spot on Panasonic PT-56LCX66
Return it my friend, it sounds like a problem on the display panel driver board, and boy is that expensive to replace! Good Luck
SOURCE: TV WONT TURN ON
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
SOURCE: R517 of main board is burned out - TV won't turn on.
lo que puede hacer es medir el ohm de la resistencia y * 2 pero desde el terminal hasta la mitad de la resistencia
I have the same problem. Sometimes the TV will turn on just fine, other times I get the red light flashing light.
