My mp4 player craig mode CMP616F is not Charging.after charging 8-9 hours and when i playing a song ,after 1 or 2 minute.it Display "Low Battery".Please Help me what should i Do for that.
Get free help, tips & support from top experts on craig cmp616f driver related ... why isnt my craig mp3 player model number cmp616f turning on? because you need ... ...craig mp3 player cmp616f. how do i turn down volume ? press the volume ...
Walmart
Rating: 2.5 - 8 votes
Buy Craig 4GB MP3 Player, CMP616 at Walmart.com. ... It looks like you are not signed in. To proceed you will need to either sign in or create a new account.
this happened to me wen i first got mine, so what in the manual the mp3 will need at 4 hours at first to be charged fully, when u charge it flip the on/off switch ON, n let it sit as long as you can. thats the only way it will charge, the reason why it keeps turning off is becuz its on low battery
Mine did the same thing. I talked with a guy at the company and he told me it was frozen. What you need to do is let it run till the entire battery is dead. Than recharge it completely. For 4 hours at least. That should reset it. Now my player works fine.
Good luck.
i had the same problem with mine searched online and found that someone said to let the battery run completely dead, (turn it on and leave it on til the screen stops blinking) that resets it, and then you charge it for 4 (i think) hours. Worked for mine and I hope it works for you too
left craig mp3/video player model cmp616f on while disconnected from computer over night. connected to computer next day seen hour glaas 2 or 3 seconds then craig blue screen . it connected to computer and stated charging again seems to have reset its noon now dec 28 2009 ill post again results when fully charged and try to use.
Got same problem with this thing. Best suggestion, remove headphones, place MP3 player in trash, tell everyone you know not to by a Craig. Hopefully they will go out of business soon.
i had the same problem with mine searched online and found that someone said to let the battery run completely dead,(turn it on and leave it on til the screen stops blinking) that resets it, and then you charge it for 4 (i think) hours. Worked for mine and I hope it works for you too
Keep your mp4 player turned OFF while charging and keep it in for an hour. Let it charge up. If that doesn't work something else will - Follow these directions carefully!
1. GENTLY hold your Craig MP4 player in hand. 2. Walk over to window and hold it near sunlight for 2 minutes. 3. Shake it gently 3 times. 4. GENTLY place it down and wait 2 minutes. 5. Grab mp4 player and smash it into trash can.
