Frigidare GLRT184RA - Fans seem to be working, cleaned coils, noticed there is frost on lower back wall of freezer compartment (top freezer-bottom fridge) Freezer is still functioning. I did notice as well the fridge is no longer making the gurgling sound it used to for the past 6 years everytime the door was shut on the fridge. Any thoughts. The fridge is 6 or 7 years old.
SOURCE: Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
SOURCE: Freezer Not Freezing
sounds like youll need to order and install one of these, its too cold in your garage to operate normally, this is a simple solution that should correct your issue
http://www.frigidaire.com/tip/US%202008%20Service%20Flashes%20and%20News/Refrigeration/2008/Service%20Flash%20RF083FRIG%20Garage%20Kit%20for%20Top%20Mounts.pdf
