Go to - menu-> settings-> application settings-> call-> all calls-> auto reject-> (scroll one down) reject list->
[on the reject list uncheck number you wish to remove from the reject list. ]
-this is the most accurate answer, trust me.
Thank u very much!!!
thnks a lot
you r the boss (y)
Go to menu-select address book-go down to number 5 rejection list and hit select-choose your moms number and hit delete from list then your done. :)
Menu->Setting->Call setting->All Calls->Auto Reject->Highligt Activation ->Off
You are indeed master. Thank you for saving me from paying Ā£11. You are good. You are too much
i have a nokia 5230. how do i add a number to reject list?
If your phone is a propel, then...
To add an entry to the Reject List follow the steps below:
delete numbers as desired
MENU>ADDRESS BOOK>REJECT LIST
How can i remove a number from reject list in Samsung SGH J600 model
I always use LEO Privacy to block calls, and when I want to remove them from the reject list, I can easily do this in LEO Privacy, you can also have a try with this applock. LEO Privacy Applock Hide Safe Android Apps on Google Play
SOURCE: cannot bring up call reject list on samsung sgh-a707
Menu
Settings
Call Settings
All Calls
Auto Reject
Reject List
Press center key
Scroll to number
Options
Delete
SOURCE: Removing Numbers from Reject list Samsung u900
Main Menu> Settings> Call Settings> All Calls> Auto Reject> Reject List> Delete the number out of the list.
Adam
SOURCE: removing numbers from reject list in samsung f480
Goto
Settings-->Call settings-->All calls-->Auto reject
Click on 'Reject list'
Here just for making them to be receivable calls, uncheck them
If you want to completely remove, you need to click on each entry and then press Options-->Delete. But the problem with deletion is you need to do that for each entry separately.
SOURCE: removing a number from reject list in my Samsung GT-S5233A.
Hi ,
just go into menu , settings , application settings(5), call (1), all calls( 1) , auto Reject (2), scroll down to reject list and you will find all numbers added to it, simply delete them and they will be back as normal in your phonebook,
hope that'll help you
SOURCE: accidently add number in reject
Go to settings = application settings = call = all calls = auto reject = reject list
i cant remove a number from the call reject list
Accidentally added a number to the reject list...how do I get it off?
how can i remove a number from the reject list?
Need to remove a number from the reject list
i cant get the # off help please
