Philips Magnavox 27MS343S 27" TV Logo
Posted on Nov 13, 2010
Magnavox KM-42010P 39716781. I do not have the remote and the TV will turn on but nenu button not working and TV will not turn Off.
Keely Johns
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 07, 2019
Keely Johns
Contributor
Level 1:
Answers
Questions
Helped
204
Points
0
I bought a universal remote from kmart today to try and access my tv menu to turn child lock off but all buttons are locked i need help
2 Related Answers
Anonymous
  • 5138 Answers
  • Posted on Dec 23, 2007
SOURCE: Plasma T.V
you need to contact phillips,magnavox consumer service which should be 1-800 number or look under www.phillips.com then type in km42010p.
gopakumarg43
  • 76851 Answers
  • Posted on May 03, 2011
SOURCE: Hi I am tring to
Hello
Buy one COMCAST CUSTOM DVR-3 DEVICE Universa Remote Control. Magnavox is listed in its codes. Codes are:
0054, 0030, 0179, 0186
You will get its catlogue and all other details, about how to enter codes, and a colde list for different devices to which this remote can be used. OK.
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
Key code 39716781 model km 42010p
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Unlock procedure to many popular brand TVs are given.
2helpful
How do I remove the closed caption or dialoge text at the bottom of the screen
U have the tv original remote wright?Yes,look at the tv remote control,look for a button that said CC,push that CC button a few times make sure all CC1,2,3..all to off closed captioning should stop.No CC button on the remote.Go into the tv main nenu look for functions like Text 1,2,3.. and closed captioning 1,2,3... turn it all to off will fix the problems also.
1helpful
Anyone know how to turn off closed caption
U have the tv original remote.Look for a button that said CC.Pushes that CC button a few times turn off all CC1,2,3.. to all off,will not have Closed Caption anymore.Or tries go into the tv nenu look for Close Captionning or Text 1,2,3 functions tun it all to of.Will get rid of Close Captionning.
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
2answers
Hi I am tring to find a MAGNAVOX TV KM-42010P remote control
Hello
1helpful
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
I have a Philips Magnavox tp3273c101 with a blue screen and a message in spanish, but i dont speak spanish. help
U talking about the tv nenu in spanish?Just pick the english one and push enter ur menu will change it back into english.
Plasma T.V
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
