Turned on the TV recently and noticed a horizontal line in the middle of the screen. The lower half was slightly darker than the top half. After a few minutes there were several vertical lines that appeared in the lower half and the images were freezing for a second or two. After about 10 minutes most of the problems cleared up except for a thin horizontal line in the middle of the screen that still remains.
half the screen is discolored pink and at the very bottom there are a few blue horizontal lineshalf the screen is discolored pink and at the very bottom there are a few blue horizontal lines
You can't post conmments that contain an email address.
Idioto, there IS no tube in an LCD tv.....it's called a tft, or thin film transistor SCREEN.Idioto, there IS no tube in an LCD tv.....it's called a tft, or thin film transistor SCREEN.
Back - light problem. [CCFL lamps inside it]. Check and replace damaged CCFL lamps. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
This is casued by the buffer boards on the right or left edge of the plasma tv. You need a direct replacement for the top buffer and then your picture will return!
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
