Insignia NS-BRDVD Blu-Ray Player Logo
Posted on Nov 15, 2010
The Insignia NS-WBRDVD blu ray player will not connect to the wi-fi network in my home after countless attempts and efforts.
lotusguy
Level 1:
Habit-Forming:
New Friend:
  • Contributor 12 Answers
  • Posted on Nov 16, 2010
lotusguy
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
12
Questions
0
Helped
3740
Points
31
This is a common problem. If you go to the Insignia web site and find the forums, you will see a 40 page list of wireless connection problems. The wireless section of this player is junk. Use the wired connection and save yourself a lot of aggravation.
3helpful
How do I reset Netflix on my insignia NS-WBRDVD
Go to the settings menu of the Insignia, click on "Reset" settings and then select "Deactivate Netflix".
Next, restart the player and access the Netflix once again to reactivate it.
10helpful
How can I connect my blue ray to my wifii connection at home? If you can tell me the steps? Thank you
To connect wirelessly to a wireless network using WPS (Wi-Fi Protected Setup):1.Press ? or ? to select Settings.2.Press ENTER. The Settings menu opens.3.Press ? or ? to select Network. The Network menu opens.4.Press ?, press ? or ? to select Wireless, then press ENTER. A list of network options opens.5 Press ? or ? to select WiFi Protected Setup, then press ENTER. A screen will appear asking you to press the button on your router.6.Press the button on top of your router.7.A screen should appear on your TV that says "Success" when your player is connected to the router.8
Press ENTER to close the message.
4helpful
Do not know the activation code for the NS-WBRDVD Insignia Blue Ray from Best Buy. Cannot streamline Netflix without it??
To stream Netflix content you will need to have a computer connected to the internet and a netflix account (even the lowest level should allow you access).
Set your NS-WBRDVD to connect to your wireless network.
Start up Netflix and select you are a new user. You will be given an activation code.
On your computer, log-in to the Netflix website: www.netflix.com On the top right of the screen you should see "Your Account & Help" Click that.
On the "Your Account & Help" screen, in the Account Information section on the bottom right of that grayed box should be "Add Blu-Ray". Click that and you should be prompted to enter the code your NS-WBRDVD gave you.
Once you enter the code and Netflix accepts it, your player should confirm and allow you to watch Netflix streaming content.
Hope this helps!
Cannot find quick set up guide for wireless internet connection.
Turn on the player.
Go to Settings.
Go to Network.
Follow the setup instructions.
If you are using the NS-BRDVD, there is no wireless radio in the unit.
If you are using the NS-WBRDVD, then these instructions should work for you.
Hope this helps.
Let me know if you have difficulties.
How do I find the ''Quick Set Up Guide'' for wireless internet connection on this website. I purchased an Insignia NS-WBRDVD and the instructions stated that I could get a guide at this website. When I try...
You need to enter your network ID, enter the passcode for wpa2 and it should connect. If you are using WEP, it won't work. If you change to WP2 all your wifi needs to change to WPA2.
You may have to select a manual code (on your Wireless Point) for WPA2 so you don't have to type in 64 characters.
You don't name the website so I cannot investigate.
5helpful
2answers
How to hook up insignia blu ray player to netflix
This model player (NS-BRDVD) is not Netflix capable. Netflix capable models are NS-BRDVD3, NS-WBRDVD, and home theater system NS-BRHTIB.
I have Insignia Blu-ray DVD player and a membership with Netflix. My DVD player references Netflix download coming soon in order to stream movies straight to the DVD player. Is that download available?
This model, NS-BRDVD, is not Netflix capable. Models NS-BRDVD3, NS-WBRDVD, and NS-BRHTIB are, however. A firmware update may be required when first setting up your player for best functionality.
3helpful
Have 2wire gateway, need to connect netflix blu ray player
On the blue ray player they don't like encryption. I had to help a friend on that and he finally disable the encryption and it work.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
