(1) Make sure
that the power is turned on.
(2) Press the SCAN button.
If you specified the same computer to
save scanned data last time, go to (5).
(3) Use the or
button (Scroll Wheel) to select PC , and press the OK button.
The computer selection screen will
appear.
Besides saving scanned data on the
computer, you can save them on a memory card or USB flash drive, or attach them
to E-mail on the computer.
(4) Select the
computer to save or forward scanned data, and press the OK
button.
(5) Select the
document type, and press the OK button.
Hope can help you.regards
Scan it as a jpeg or whatever it is scanning as. then you can open the scanned image and
save as a pdf
Turn on your samsung all-in-one device. Put your document that you want to scan face
down on the tray of the samsung all-in-one.
Open your samsung device manager on your personal computer or your Mac. Choose
the "Scan" function. This will be slightly different depending on whether you are on a PC
or a Mac andwhat samsung all-in-one model you have.
Hit the "Scan" button on your samsung all-in-one or the "New Scan" button in the top left
corner of the software on your computer.
Click the drop-down menu at the bottom right of the scan window, below the image. Choose
the "PDF File" option. Hit the "Accept" button. A dialog box that allows you to save your PDF
in a location of your choice will appear.
5
Type a name for the PDF in the "Save As" field. Choose a place for it on your computer with
the drop-dowm menu. Click the "Save" button. Your scanner will then scan the PDF and save
it.
