Locating the Thermal Fuse
In GE dryers, the thermal fuse--sometimes called a safety thermostat--is located behind the drum on the inside of the dryer. ... Look inside the dryer, behind the drum, to find what looks like a round metal pan. This metal pan is actually the dryer's heating element housing.
On ge dryers the fuse will look like this: about the size of a dime black and has two yeller wires. Ya gotta take it apart to get to the fuse and see why it blowed. Clean it up get all that lint out I have a page on ge dryers here: GE DRYER REPAIR
the thermal fuse located on the inside rear wall of the dryer to the right side of the heating element behind the drum is open,on any GE dryer of this type if this fuse opens it kills the whole dryer operation..........no nothing,nada
You will need to check and see if the dryer has a bad thermal fuse on it. If so, it will cause the dryer not to start.
The thermal fuse should read closed for continuity. The thermostat is number 507 on this diagram. It is located on the top of the heating element housing.
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
