Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
Posted on Nov 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn it on ..... i see smoke pls help - Cobra 29 WX NW ST 40-Channels Base CB Radio
Anonymous
Level 3:
Guru:
  • Master 773 Answers
  • Posted on Nov 17, 2010
Anonymous
Master
Level 3:
Guru:
Answers
773
Questions
0
Helped
269149
Points
1660
Do you like your radio medium or well done?
You may have hooked your power wire up backwards at some point and blown the polarity protection diodes.
This requires opening the radio and using a soldering iron to remove and replace the blown diode.
You will need:
1. Soldering Iron
2. Solder
3. De-soldering braid
4. N1004 diode or better.
5. Phillips head screw driver.
Using the phillips head screw driver to take the bottom cover of the radio off being careful of the speaker wires. Using the soldering iron, heat the solder on the tabs of the speaker and pull off the wires. No need to use the de-soldering braid to remove the solder. You should do this to make it easier to handle the radio, and to avoid damage to the speaker or wires etc.
Now take the cover off the top of the radio. This will reveal the "Trace" side of the board. This is where all of the components are soldered to the board.
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D23. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D23 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Once you have located the points at which the diode is soldered too, do not de-solder it yet. Make note of which side of the diode the white band is on. This is important, putting the diode in with the wrong polarity will make the radio not work.
After you take note of the white band you may now use the de-soldering braid to remove the solder from the trace side of the board. To do this, place the braid over the solder point. put the tip of the soldering iron on the braid and press it down to the solder point. You will see it **** the solder into the braid.
Once the solder is off both solder point, flip the radio and remove the bad diode.
Put the new diode in, making sure the white band is on the same side as the original diode.
Once again flip the radio over to trace side of the board and solder the new diode in. To do this place the tip on the solder point, making sure to touch both the solder point of the board and the wire from the diode. take the solder and touch it to the solder point, not the soldering iron tip. Once enough solder is on the point you can remove the soldering tip. Don't use too much solder.
Once both points have been re-soldered, solder the speaker wires back to the speaker. Red is positive, it connects to the tab marked by the positive symbol "+". The white wire is negative. It goes to the negative symbol, "-". You can just reheat the tab, and put the end of the wire into the melted solder and remove the solder tip while holding the wire in place until it cools enough harden again.
After the speaker is re-soldered, Put the covers back on. Now be very careful hooking up the radio to power. If you hook it up backwards again it will blow the diode again. Once the power wire is connected, turn on the radio, it should work fine at this point.
Good Luck!
1helpful
Corsa gsi 1.8 lost power and lots of white smoke what can the problem be its a 2006 model pls help me
White smoke is a dinner of a cracked or warped cylinder head, a cracked engine block, or head gasket failure usually caused by overheating. Take it to a mechanic.
My juicer started smoking and wont turn on ! i just bought it !!! pls help
Sounds like the belt that drives the blades broke. You will need to bring it back to the store in which you bought it from if it is still under warranty. Otherwise, get on the Breville website, register your product, and then find out about the warranty and returns.
1helpful
My fridge/freezer made a buzzing noise, then hot smell, then smoke then stopped cooling/freezing. It is still running and powered on, no more smell, smoke, etc.
need model #` but it sounds like a control board . .. more info needed .. to help you more mod ser # .. sxs ? or top freezer things like that .. but it sounds like a main control board .. mm hope this helps feed back pls ..
2helpful
MY HERO HONDA SUPER SPLENDER (ONLY 1 YEAR n 4 MONTHS OLD) IS SMOKE A BLACK FUME...N GIVING AVERAGE ONLY 35 KM PER ONE LITTER I WERE REPAIR MY CARBURETOR & REPOWRING OF PLUGS... BUT MY BIKE DONT STOP...
Black smoke means the fuel mix is too rich. Assuming you have not changed the jetting, I would say the float level is set too high. The only other possibility would be a main jet that has come loose.
2helpful
2answers
Pls where is Swirl Control Solenoid Valve located in Infiniti QX4
This link shows the location of the SCV, If your motor is different the location should be similiar. http://img510.imageshack.us/img510/5687/vacuumdiagramuh3.jpg
There's a vaccuum line that runs off the SCV to the SCV check switch.
P0442: Have you inspected the lines, charcoal cannister etc? Make sure the fuel cap is tight. The easiest way to check the system is to have someone perform a smoke test. I had a DTC on my car which indicated a EVAP problem, it turned out to be the Fuel tank evaporator Control Solenoid.
Smoking Fan Assisted Oven
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
1helpful
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Battery empty!
just have the phone exchange or buy a new one
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
