No one provide you free unlock code. If anyone provides some codes and that code does not work then your phone will permanently locked. Codes generate from server based on your IMEI so nobody will give you free.
There can be many ways to get your unlock code. If your contract period is complete you can ask your cellular operator for the unlock code. But, they do make it very difficult for you to get the code.
You can also visit Unlock-zone.com and can see different options there to get unlock code for a price. Choose any price appropriate for you.
Hope this helps
SOURCE: i would like to unlock my ex-contract lg kg800
To Unlock KG800/LG Chocolate Follow these steps
1. Insert sim from the network that it is locked to.
2. Turn on phone
3. On home Screen, Slide up phone
4. Type 2945#*#
5. ENG. Mode menu should appear
6. Go Down to Factory Reset Select it, may take a few minutes to reset.
7. This will reset the phone back to before the Phone was locked to a network.
8. The phone will automaticaly Restart(Note The Network Logo At start up will not change)
9. Now insert Any simcard(Not tested with 3 sims)and the phone should turn on normaly
10. The phone is now unlocked and you can customise the setting as you like. Make sure to choose GSM Network, so that you can call from anywhere in the world.
You'll now be able to sign up to whichever carrier you want. You just have to buy a sim card for thier network, and a plan. Month to month... if you like.
SOURCE: Unlock for LG TG-800 (similar to KG800)
where is information stored on this phone (mainly the contacts)? the phone itself or the sim card?
SOURCE: unlock code
Try this sollution:
Insert an accepted Simcard.
-Press 2945#*1201#
-Menu
-Settings
-Security Settings
-Sim Locks
-Select Lock Type
-Deactivate
NCK: 5977825?
SPCK: 825?3583
Please note that ? can be any number except 0 and 7. Try them all.
i hope it will work
so don't forgot to vote me
SOURCE: Unlocking LG KG800
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
SOURCE: LG KG800
PHONE UNLOCK PROCEDURE
Please follow the instructions below to unlock your LG KG800 handset:
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Enter 2945#*7101# while in standby mode
4. Select Menu, then go to Settings > Security > SIM Lock > Network
5. Select Deactivate and enter the 8-digit NCK unlocking code provide for your handset..
6. The handset will be unlocked automatically and will display "Done".
