There is a seal in the pump housing, but u have to take off everything to replace that seal! The manufacturer recommends replacing the PUMP ASSEMBLY itself when there is LEAK. The leak are caused by debris from clothes and materials u left in ur pockets. The cleaning of filter in ur drain system is 6 months and a tiny SOLiD materials will cause havoc to ur impeller pump itself! U could try repaing the seals in the pump or buy whole assembly! Hope that might help u out! Taah!
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
You're right, there was some very small hard debris in the housing unit when I cleaned out the filter. Is it possible to fix or replace the seal? Replacement pump is $250.00 plus shipping and taxes.
yes
where do you get a new seal between the pump and filter clean out
