If you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
where is the lever?????
and where is it mentioned in the manual????
I found the lever. Thanks so much, there a lever in the back its #19 in the manual where the parts are displayed. You grab the lever and pull it down.
There is a buttonhole bar that you have to drop down. It's located on the left side of the pressure foot and you just grasp it with your fingers and pull it downward. The beep goes away and the machine will run! Good luck!
Put button into the buttonhole foot. Push the slider on the foot so machine can "read" length to sew the desired buttonhole, and pull down the Button Stop lever located to the left of the needle bar
