Same problem
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
If the fan does not turn does lamp not turn on also?
I changed the fan and it still does not power up. When I plug the power cord the turn on button flashes slowly green. When I press the power button it turns solid green as it should but nothing turns on, not the lamp and not the new fan I installed. After 4minutes the lamp amber warning light comes on. (means change lamp)???
I have the same identical problem. The unit was given to me and I don't know the condition of the lamp but the fans should at least come on.Took the top cover off and observed that the color wheel was not spinning either.
