Kenwood KDC-135 CD Player Logo
Posted on Nov 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot assess my aux input on kdc 237 - Kenwood KDC-135 CD Player
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
620
Points
Press src hold menu button down,press seek button up to change option to "auh" press seek button left or right till it says on. problem solved i had to figure it out myself good luck
Anonymous
Level 2:
  • Expert 35 Answers
  • Posted on Nov 16, 2010
Anonymous
Expert
Level 2:
Answers
35
Questions
0
Helped
12248
Points
174
  • Selecting the (SRC) button to "AUH" which is the auxiliary input.
  • If this does not work.
  • Then set the unit to standby mode. By pressing the (SRC) button until "STBY" is displayed. You need to check that "On AUH" is enabled. Now try the "AUH" again.
I hooked up an aux cable to my KDC-MO4028 but the aux input option is not coming up as an option for one of the sources.
Hi David,
A decent info page for this radio and options is at Crutchfiled. They seems to provide good / very good information on all the products they sell. Service and pricing is up to you. To use Aux inputs, you need to purchase and connect the optional Aux Input Adapter (picture below).
Crutchfield sells these for about $20, and they plug into the jack on the rear of the radio. The jacks on the cables attached to the radio are preamp outputs - not inputs; and will not work as an input.
Here's a link to the manual (free download). Good luck!
Where to insert the aux input in the kenwood kdc-mp528
Its going to be in the rear of the radio RED/WHITE RCA should say aux input. you will need a RCA to 3.5mini cable
2helpful
2answers
I have an aux input on kdc 237 with the wire which i have previously used, i cannot figure out how to set it up so that the aux is on screen.
Change mode to Standby and then scroll through until you find the AUX and click the right hand knob to the right to enable the Aux Mode. Then simply change mode to Aux
11helpful
Can;t play my Ipod through Kenwood KDC 237
i was just having this same problem but i pressed standby and menu and scrolled up till i got to a AUH which is off all i did was turn it on and press standby again and my ipod started playing
10helpful
Cant seem to get the aux up on my kenwood kdc-237 tried from src button but to no avail can anybody advise please
Its becuase the aux is turned off as default so you have to activate it.
Put the unit into standby mode
Press menu for at least a second untill menu appears and then select the aux option and edit it to either aux on1 or aux on2 or aux off.
Anyproblems and you can download the pdf for free from internet
AUX input won't work
The red and white RCA terminals on the back of the unit are generally outputs for amplifiers. To use AUX the unit will need to have a 3.5mm jack in the front or rear. If not than the unit does not have AUX input capabilities.
Kenwood KDC-237
i have the same problem...
5helpful
3answers
Ipos nano 3
It will work bu tonly after enabling the aux jack.
Place unit in standby mode then press menu for a second and then goto aux and select it to aux on1
I have a Kenwood KDC MP2035, it is brand new, I try listening to somehting plugged into the AUX but when i press SRC to select AUX, AUX does not show up, only TUNER and STANDBY are in the options so far
here is some thing that will help u out. AUX Input: The KDC-MP2035 is equipped with a front panel 3.5mm minijack auxiliary input for connecting external portable audio devices such as an MP3 player or Tape walkman. The receiver allows you to select between the following AUX settings.
  • Off: the source button does not scroll through the AUX input when function is turned "off"
  • Aux 1: turns on the AUX input for use
  • Aux 2: turns on the AUX input in the attenuator mode - press the attenuator button to activate sound. pleas let me no if i can help any more and dont be afraidto rate me i dont bite lol just kidding
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
