Question about Miele Washing Machines
Waterproof fault - Miele Washing Machines
  • 1 more comment
  • Anonymous Apr 20, 2009
    My liele washing machine is showing up waterproof fault and I can't get rid of it.
  • svoorhees Jan 17, 2019
    Same error on mine along with beeping. I turned it off and opened the flap on the front to expose the screw plug drain. With my wet vac ready, I unscrewed it and sucked up about a liter or so of drain water. There was a blockage that came out. Turned machine on and same error and beep. Tilted machine forward, released more water and then tried it again and the error is gone.
    Well, it did it again. This time I had to open the top, then the front panel, then the sides to reveal the base pan where that 2nd bit of water seemed to be coming from when I tilted the machine. It was still a bit wet around what looked like the sensor. I couldn't see any problems, so I ran the machine to see if I could see where the leak was. There was a tiny leak in the soft black hose under the drum. Inside I could feel lots of objects so I opened it and out came all sorts of things including a screw which must have made the hole. have ordered a new Miele Drum To Pump Sump Hose for £50. Ouch, but at least it'll work again. Lets hope.
  • 4 Answers
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Posted on May 31, 2009
  • 8 more comments
  • Fionas123 Dec 12, 2010
    Brilliant! This worked after a burst pipe had created this fault message. Saved Lots of time, worry and money. Thank you!
  • mhclarke828 Dec 26, 2010
    FAB! My error message came up on xmas eve after a frozen drain pipe problem, I sorted that out and was going to call Miele on Tuesday - Great solution and the washing is on. Thanks very much, saved me a bomb
  • catherinelan Dec 31, 2010
    catherine My message came up on 30 Dec - great, very convenient!! Miele costs a
    fortune and take their time coming. Followed your instructions and it
    worked. Thank you so much - saved me £95 call-out charge what
    ever else they would have charged for pulling the machine out and just
    tipping it forward. Brilliant.. Most of Miele's silly 'send for the engineer'
    messages go just by turning the machine off and on again.... but not this
    one.
  • pauliandunca Jan 25, 2011
    Superb, after being told by Miele that there was a 8 day wait for the engineer, this worked perfectly. Yeah, clean undies are already on the way.
    Thanks.
  • mayepiphany Feb 13, 2011
    THANKYOU SO MUCH!!! I bought this machine because of their great reputation and is cost nearly 900euro. Just after my 2 month guarantee was up, this fault showed. Your instructions worked perfectly. Miele were going to charge me nearly 500 euro to have it fixed, which is shocking. If you have had any problems with thier tumble dryer let me know because mine broke down at the same time. Thanks so much again, Sarah
  • Sarah Wright Nov 12, 2011
    Thank you!! Just solved my problem too. Washing back on, fingers crossed it is the end of my problem.
  • Cath P May 23, 2012
    Thank you so much. After opeing the drain filter lid to find a button, I didn't close it properly so I had the waterproof fault message. I knew it wasn't an electrical fault, just my stupidity, and your method worked perfectly. It saved me waiting for a technician and the cost of their service fee for something that ened up being relatively easy to fix. Again, thank you!
  • joanna791
    joanna791 Apr 08, 2013
    I have a miele Novotronic w1614 and I have the same fault but can't open the drain cover - can anyone give me any clue?
  • joanna791
    I have a Miele novotronic w1614 with the same error but I can't open the drain cover - anybody know how?!
  • Federico Ghirelli
    Federico Ghirelli Jul 30, 2018
    Worked great! Thank you!
Thank you for this solution, donno how i didnt think about it myself, got the same problem on M4144, opened the valve, emptied the water and it works again.
Posted on Feb 13, 2012
    New Friend:
Thankyou Halldor. You have saved the day...... Husband was on the verge of taking the whole machine apart until I read your solution
Posted on Feb 28, 2019
    New Friend:
Yes, but the problem repeats after few times that I use it! it doesn't make sense that I have to do it every time. any other solutions?
Posted on Jan 19, 2016
    New Friend:
Worked for me too :-)
Posted on Dec 17, 2015
    New Friend:
Perhaps the machine is not level -> water stays
Posted on Jun 03, 2015
    New Friend:
Hi.
And it works for me, here in Denmark
Thx
Poul
Posted on Nov 23, 2012
  • 1 more comment
  • kronkvist
    kronkvist Nov 23, 2012
    Hi.
    Thx
    Poul
  • Halldor Sigurdsson
    Halldor Sigurdsson Apr 08, 2013
    Glad I could help.
  • Gary Kinsey
    Gary Kinsey Jan 23, 2019
    And it worked for me too, here in the UK. Thx :o)
6ya staff
SOURCE:
How to get details about basement waterproofing company va?
You should find a local waterproofer to give you an estimate.. some waterproofing could be done from the inside without digging up your yard. Basement Waterproofing We Fix Leaky Basements MT Drains
Mar 03, 2017 | Computers & Internet
It is displaying the message and beeping at me waterproof fault
Put a towel down in front of machine. Tilt machine forward. Water should run off the sensor plate and fix this problem.
Jun 20, 2015 | Miele Novotronic Premier 500 Front Load...
What's the best way to waterproof the Timverland
Nope! But if you get wet, put it near a heater or something else hot. It will help you.
Aug 17, 2013 | Clothing Accessories
Are metal detectors waterproof?
almost all modern metal detectors are waterproof, since many people who enjoy this hobby do so on the beach. it depends on the coil inside, some are simply waterproof, and some are completely submersible
Jan 15, 2013 | Retail Supplies
I have a 2005 Kawasaki z750s. Both headlights went out at the same time. My tail lights and all dash lights work. Is it a fuse or wiring?!
Possible water damage to head light relay in the fuse box under the seat or the stator which controls the head light relay. Get a auto electrician to do an trace check on the wiring & connections to rule out all other faults. If the lights cut out after an heavy bump and come back on after a set time, the fault could be the relay or stator. Have the auto electrician resolder the relay connections in the fuse box (about 40 connections), also have an 12v LED warning light fitted to the stator connections with enough wiring so the LED can be mounted on the handle bar. If the LED cuts out the stator is at fault(very costly), if the LED stays on the head light relay is at fault. Also better waterproof the standard fuse box , the case is not that waterproofed (easy done with insulation tape). Hope this helps.
Dec 11, 2011 | 2008 kawasaki Z750
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
2. Unplug it
Jan 04, 2011 | Washing Machines
Miele w3725 front loader. message on screen "waterproof fault"
For our model Alemnesh's suggestions were spot-on. It's hard to believe that a machine with such a good reputation would (a) allow this fault to occur so easily and (b) not have its own manual provide explicit guidance as to how to fix it.
Oct 03, 2010 | Miele Washing Machines
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Washing Machines Logo
12,204 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
