SOURCE: sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
SOURCE: No Video or Audio on HDMI on Sony STR-DG800
I dont have the exact model you do, but on my sony receiver I have to enter the setup menu and define where the input is for the device I am using. For example I have to tell the receiver to use the optical audio input instead of the RCA Stereo. Otherwise its on default.
Also, you do know this model of reciever offers only pass-through audio on HDMI? that means no surround sound!!! Thats really silly but thats the specs for this model. To get surround you'll have to use optical. otherwise , with HDMI through this sony you are adding an extra component to tyour system with no benefit other than maybe power amplification.
SOURCE: I NEED TO RESET Sony STR D365 Receiver BACK TO
I believe what you want to do is as follows. Turn off the power supply. Hold the buttons 6, 7, 8. And turn on the power. The display should activate all options, then turn on and off a few times and finally display End. Then the memory should be reset back to Factory.
