2001 Chevrolet Tahoe Logo
Posted on Jun 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RADIO INSTALLING COULD SOME ONE TELL ME THE COLOR CODE FOR WIRING A BOSE RADIO IT HAS 16 PIN PLUG TOP ROW FIRST FIVE PINS ORANGE,YELLOW,GREEN,GRAY,YELLOW AND PURPLE. SKIP 5 PIN HOLES TAN,GREEN,BLACK,BLUE, AND LAST ONE EMPTY. BOTTOM ROW GREEN,SKIP 4 PIN HOLES BLUE SKIP 1 PIN HOLE LT GREEN, BLACK WITH WHITE STRIPE, BROWN WITH WHITE STRIPE, GREEN WITH WHITE, BROWN, BROWN WITH WH, LT GREEN WITH WH, LT GREEN, BLACK WITH WH. AND LET ME KNOW EMAIL [email protected] thank you
A
Anonymous
With the bose sound system you have to bypass the audio system through the factory amp. the factory is located behind the right side of the glove box.
Anonymous
Level 3:
  • Master 1,010 Answers
  • Posted on Jun 25, 2008
Anonymous
Master
Level 3:
Answers
1010
Questions
6
Helped
630740
Points
2385
There is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Radio diagram for 2016 nissan versa
Hi there, Try this...
Radio 12V yellow + radio, white 20 pin plug, pin 19 Radio Ground (chassis, base audio); black/white (except base audio) - radio, white 20 pin plug, pin 20 Radio Ignition blue + radio, white 20 pin plug, pin 7 Radio Illumination lt. green (parking light); black (dimmer, without navigation) +,- radio, white 20 pin plug, pins 9, 8 Power Antenna black + radio, gray 3 pin plug, pin 1 Left Front Speaker (+/-) gray - pink +,- radio, white 20 pin plug, pins 2 - 3 Right Front Speaker (+/-) beige - violet +,- radio, white 20 pin plug, pins 11 - 12 Left Rear Speaker (+/-) white - red +,- radio, white 20 pin plug, pins 4 - 5 Right Rear Speaker (+/-) blue - yellow +,- radio, white 20 pin plug, pins 13 - 14 Aux. Audio Input Left (+/-) yellow - green +,- radio, white 32 pin plug, pins 31 - 15 or white 24 pin plug, pins 10 - 11 Aux. Audio Input Right (+/-) blue - green +,- radio, white 32 pin plug, pins 16 - 15 or white 24 pin plug, pins 12 - 11 RSE Video (+/-) green - (shield) (rear view camera video) +,- radio, white 24 pin plug, pins 16 - 15 Satellite Radio 12 Volts (built into radio on premium audio)
Good Luck
Mr.Mike
Hi, I have a hyundai sonata hybrid 2013. Scan test shows code " P0A2D" hybrid motor temperature sensor high.
Hyundai has a tsb on this code it is 16-at-005 basically it breaks down to this: remove air cleaner find extension motor wire disconnect and measure resistance on pins 2 and 7 which if looking at male pins top row from left over 2 and bottom from left over 2 is pin 7 resistance is 112-142 kila ohms now disconnect trans temp sensor connector measure the resistance on pin 4 top row from left and pin 8 bottom row from left should be same 112-142 kila ohms at outside temp 68 . if reading are not the same resistance replace transaxle,if they both are same resistance replace HPCU (hybrid power control unit ) next step if resistance is different by 1 ohm harness is good,if resistance on both readings are different by more than 1 ohm replace extension wire . may need to send this car to dealership if this testing is more than you can provide yourself,sorry hope it helps
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Wont commnicate for inspection
Check all the fuses and I mean all the fuses. This is generally caused by the OBD II connector not having power on pin number 16. Pin 16 is the last pin on the shorter row of the connector but, you have to know the orientation. If you look at the connector on the car, READ THIS CAREFULLY, if the connector is wider at the top, the pins are numbered from left to right. The top row is numbered 1-7 and the bottom row is 8-16. If the connector is wider on the bottom, just invert the above instructions. Check to see if the connector has battery power to pin 16 and ground on pin 5. DO NOT GO PROBING AROUND THE OTHER PINS!! If the vehicle is running and the MIL light is on when the ignition is turned on and goes off when the vehicle starts, your problem is probably right there. Let me know how you make out.
07 chevy suburnan wiring diagram color
Item12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio Tunerspacer.gifspacer.gifWire Colorred/black (60A), red/black (60A)red/white (x4) (15A each)purple (for starter kill only)pink/black (resistor code), white (5V reference)pinkN/AN/Abrown or yellowsame as second starterN/Asame as second starterdk. green (low speed GMLAN)tan/black (high speed GMLAN)tan (high speed GMLAN)dk. green (low speed GMLAN)use Directed interface modulesee power lockgraypurpletanlt. bluebrown (L), brown (R)whitelt. blue/white (F); yellow or yellow/black (R)dk. blue/white (F); dk. green or dk. green/wht (R)whitedk. green (ground to turn off autolights)dk. bluegray/black (ajar), tan (open)black/white or tan/whitelt. blue/blacklt. green/blackgraypink/blacksame as trunk/hatch pinpink/blackgray (liftgate), pink (liftglass) (rear handle sw)lt. blue (liftgate)N/AN/AN/Aarms on lock with door openlt. green (driver door key cylinder)Passkey and ignitionN/ANOT pinkN/AN/AN/Adk. green/whitepurpleorange or black (L), orange or black (R)dk. blue (back and cushion)dk. blue (back and cushion)dk. green/white (some models only)lt. blue/white (functions with ignition on only)lt. bluetangraydk. blue - browndk. blue - browndk. blue - browndk. blue - brownbrown - org or lt. blu (function with ign on only)N/Aorangesame as memory seat 1N/Ared/whiteblack(low speed GMLAN)yellow (dimmer)same as power antenna (some models only)whitetan - gray or tan - dk. greenlt. green - dk. green or lt. green/white - org/blkbrown - yellow or brown/white - browndk. blue - lt. blue or dk. blue - tandk. blue - orange (with surround)white - pink (with surround)yellow - (bare wire)white - (bare wire)dk. green - white/blacklt. blue - purplewhite - purplered/whiteblack(low speed GMLAN)(coaxial cable)brown/white - tan/whitedk. green/white - graydouble DIN6.56.55.255.25spacer.gifspacer.gifPolarity++++9.6K ohms+++6.3K ohmsdatadatadatadata5 wire5 wire5 wire-+-++--+----+---+-ac+reverse+ latched--ac+--+AAAA-+2.26Kohms+4.26Kohms+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+-+,-+,-spacer.gifspacer.gifWire Locationdash fuse box, black 40 pin plug (X1), pins F1 and E3BCM, black plug, pins 1, 2, 3, and 4starter or underhood fuse box, blk 50 pin plug (X2), pin F1 or F5ignition switch or BCM, lt. green plug, pins 2 and 4ignition switch or BCM, lt. green plug, pin 14ignition switch or BCM, lt. green plug, pin 21PASS-Key III+ Module, black 5 pin plug, pin 4data link connector, black 16 pin plug, pin 6data link connector, black 16 pin plug, pin 14data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10driver kick or dash fuse box, black 14 pin plug (X3), pin B4driver window switch, brown 16 pin plug, pin 8driver kick or dash fuse box, black 14 pin plug (X3), pin B1headlight switch or BCM, white plug, pin 8underhood fuse box, black 30 pin plug (X3), pins A7 and F7hazard switch or BCM, lt. green plug, pin 19BCM, brown plug, pins 4 and 1BCM, black plug, pin 5; brown plug, pin 2headlight switch or BCM, white plug, pin 12headlight switch or BCM, white plug, pin 17BCM, white plug, pin 22driver window switch, brown 16 pin plug, pins 13 and 11passenger window switch, brown 16 pin plug, pin 13BCM, pink plug, pin 15BCM, pink plug, pin 14BCM, white plug, pin 5BCM, pink plug, pin 12hood switch or BCM, black plug, pin 17BCM, pink plug, pins 13 and 24passenger kick, harness to reardriver window switch, brown 16 pin plug, pin 4any fuel injectorECM, black 73 pin plug (X1), pin 50driver kick, harness to reardriver and passenger window switch, black 10 pin plug, pin 7driver window switch, gray 14 pin plug, pin 6passenger window switch, gray 14 pin plug, pin 6EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5brake switch or BCM, brown plug, pin 6parking brake switch or BCM, brown plug, pin 16horn switch or BCM, brown plug, pin 18BCM, brown plug, pin 20driver window switch, black 6 pin plug, pins 3 and 1passenger window switch, black 6 pin plug, pins 3 and 1left rear window switch, black 8 pin plug, pins E and Hright rear window switch, black 8 pin plug, pins E and Hsunroof switch, black 8 pin plug, pins 6 and 4driver window switch, gray 14 pin plug, pin 5radio, black 14 pin plug, pin 1radio, black 14 pin plug, pin 8radio, black 14 pin plug, pin 7radio, black 14 pin plug, pin 6radio, black 14 pin plug, pins 2 and 9radio, black 14 pin plug, pins 3 and 10radio, black 16 pin plug, pins 5 and 13radio, black 16 pin plug, pins 6 and 14radio, brown 16 pin plug, pins 3 and 11radio, brown 16 pin plug, pins 4 and 12radio, gray 16 pin plug, pins 1 and 9radio, gray 16 pin plug, pins 2 and 9radio, gray 16 pin plug, pins 7 and 15radio, gray 16 pin plug, pins 3 and 11radio, gray 16 pin plug, pins 4 and 11Digital Radio Receiver, black 16 pin plug, pin 16Digital Radio Receiver, black 16 pin plug, pin 9Digital Radio Receiver, blk 16 pin plug, pins 2, 1Digital Radio Receiver, blk 16 pin plug, pins 3, 4center of dashleft front doorleft front pillarright front doorright front pillarleft rear doorleft rear pillarright rear doorright rear pillartop center of dashunder front of center consoleunder passenger dash, behind glove boxspacer.gifspacer.gifPhotohas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifspacer.gifspacer.gifNotehas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifspacer.gif
3helpful
My daihatsu sirion abs light was always on what is the problem and how to fix it
Hi, the light is basically telling you that there is a problem with a sensor or the sensor circuit. Find the eobd 16 pin plug and bridge the fourth pin on the top and the fifth pin on the bottom row with the ignition off. Now turn the ignition on and the light will flash and display codes. The series of first flashes indicates tens n the second series shown after a longer pause between flashes. Eg code 21 would be 2 flashes then a pause and one flash thereeon. The codes can be gotten from toyota nation. This will direct you to which sensor is faulty. Once the repair is done pump the pedal eight times and the light should blink constantly. Now turn off the key and pull out the bridging wire. Enjoy!!
2helpful
When using a jumper wire to retrieve ABS trouble codes on a 2002 Trooper 4 wheel drive how is the DLC numbered? I mean which pins do I jump? And when I do jump, Will the ABS light flash te codes....
ok, there are 16 pins in the DLC you want to jump #4 and #12 as you look at the connector from left to right top row is 1-8 bottom row from left to right 9-16, both rows the 4th pin jump them together. then count the flashes all codes are 2 diget ( example flash-flash pause flash-flash = code 22 )
1helpful
Need to locate door ajar curcuit on 2002 F150 Super Crew
The door ajar wire is the Black w/ Pinks tripe wire, on the SuperCrew the driver's door is solo, and the other 3 are are in the same input to the GEM.
The passenger's side kick panel ( the plastic that covers the Fuel inertia switch ) is a connector C206, right above C203. There is another smaller looking connector above C206, and some small 2 pin ones shown back there, along with 2 ground lugs in the side of the cab sheet metal.
C206 is a square 16 pin connector, 4 pins by 4 rows.
C203 is also a square 16 pin connector, 4 pins by 4 rows.
The higher of the 2 connectors is the one you want, the Black w/ Pink stripe wire is in the outside column, 2nd to the last from the side farthest from the tab.
Looking at the connector with the tab on the top, the outside column should be ( from tab end ) :
pin #1 : Dark Green w/ Orange Stripe
pin #5 : White w/ Light Green stripe
pin #9 : Black w/ Pink Stripe <- This is the one for all 3 doors
pin #13 : ( bottom ) White w/ Light Blue stripe wire
The connector is numbered on the top row, under the tab ( that is why the pin #s are spaced out reading down the column ).
The wire in the door is in a loom, it is coming from the door latch ( that is where the switch is at ), so it might not be obvious.
It should not be in the connector for the door lock switch ( that is Pink w/ Black stripe wire, not the same ).
1helpful
No power to radio but fuse is ok
You will need to remove your radio to check this. They have 2 different radios for your vehicle. When you pull out your radio that is how you will tell. One will have 16 pins in the plug for the radio or it will have 7 pins for the plug in the radio. If you have the radio with the 16 pin connector the your power wires are pin # 7 a yellow with a green tracer wire and pin # 16 an orange with a black tracer. Your ground will be pin # 8 a black with a green tracer wire. If you have the 7 pin connector then your power wires are pin 1 a orange with a black tracer and pin # 3 a yellow with a green wire. Your grounds will be pin # 2 a black with ayellow tracer and pin # 6 a black wire with a green tracer if you have all of that then the radio has probably failed.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
