SOURCE: TV power light comes on but no picture/no sound
The control panel, or the circuit area that reads the control panel, or the uPC is not functioning properly for reading the control command. The service tech will try a new control panel assembly, or the module(s) that have the related circuitry. Once the defective modules are replaced, the tech will leave in the new modules.
When under warranty and these sets are exchanged under warranty, they give you back a set that was serviced from someone else. That is the drawback with having the set serviced under warranty.
Jerry G.
SOURCE: Color shift to green on non hd channels
change out your box. thats why they rent them. they anticipate your going to have issues thats why they rent them. i have gone through about 12 boxes over 5 years. change res to 1080i
SOURCE: Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Testimonial: "Plug and outlet are ok, well drop it off at best buy to fix. Thank you."
SOURCE: My Westinghouse LTV-32w6 HD has sound but no picture
You may have problem with the T-C0N board, worst case will be the main logic board, try cooling the T-CON board with electronics freeze spray to see if the problem will go away, you can get it from Radio Shack.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
